Im not that mechanically minded so a diagram or laymans terms please!
Where would I find?
tim leech
- x 12
Where would I find?
The manifold pressure sensor on my MK1 Xantia 1.8i 8v please, im eager to locate it and give it a clean out as im told by Sir Jim that this may be a reason why it doesnt run right.
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
MikeT
- x 232
The MAF? It'll be somewhere between the air filter and engine. Either in the pipework or the manifold. Look for an inline device in the induction system that has two or more wires plugged into it.
Please be aware the small sensing wire is very delicate and easily broken but will probably have a coating of cooked on crud. Worth spraying with carb cleaner but if you have to rub it, be gentle and use something no-abrasive like cotton wool etc.
tim leech
- x 12
- x 5672
I think there may be a bit of confusion here MAF and MAP are not the same.
I haven't a clue where the MAP is but either Cloggz, Addy or VertVega have a description that I'll try and locate.
The MAF is as Mike described but it only senses the airflow (Mass Air Flow (meter)) and in mine also the temperature of the incoming air.
This is mine:
yours will be similar. (click for larger image).
The MAP, as you'd expect, measures the pressure in the inlet manifold.
This is mine:
yours will be similar. (click for larger image).The MAP, as you'd expect, measures the pressure in the inlet manifold.
- x 94
vince
- x 13
tim leech
- x 12
MikeT
- x 232
DickieG
- Monaco's youngest playboy
- x 33
I think you'll find the sensor located on the offside of the bulkhead with a vacuum hose running to the manifold. Remove the hose from the sensor then blow through the hose to see/dislodge any sludge build up in the manifold take off point.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
tim leech
- x 12
tim leech
- x 12
Well if found it, its a small flat plastic box with an electrical connector and a pipe coming out of it?, gave it a good blow but didnt seem to do any difference! I cant suck anything out or blow through it if you know what I mean. When i took the pipe off the car rang like a bag of nails, is it worth cleaning it out with anything?
DickieG
- x 33
You won't be able to suck or blow anything out of the sensor, what you need to check is whether there is any obstruction at the manifold end of the vacuum pipe. Remove the pipe from the sensor then blow down it. i.e. towards the manifold as there is a tendency to get a build up of sludge where the pipe is tapped off of the manifold.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
tim leech
- x 12
tim leech
- x 12
MikeT
- x 232
The MAF is part of a complex system so it could have been contributing, despite a new unit not curing the overall problem. Additionally, you might have to give the ECU time to re-learn and re-calculate it's maps which can only happen once it's up to temperature and running in closed-loop mode.
Have you had the codes read and if so, what was the result? It's relatively easy to test these sensors if you're inclined and have the time. I'd start with the engine coolant (prime suspect) then the HEGO (though it shouldn't create excessively rich conditions) if it's running rich. Whatever you do, try not use it unless cured as the excess fuel can destroy/poison certain components eventually.
