Xac's adventures with Cassy (and friends + wife)
KP
x 27
Unread post by KP »
I think you two are going Quackers......
i'll get my coat!
x 8431
It happened to me a long, long time ago Will :lol: :lol:
:roll:
Xaccers
x 188
Unread post by Xaccers »
Well, I cleaned up the pump as much as I could and it's now got veg seeping out the front from the top seal.
Been tied up this week Jim so haven't been able to pop over.
Is it a pump off job or can the top be removed in situ?
DIY sphere tool
KP
x 27
Unread post by KP »
Sorry to hear its the pump Xac :(
Is the veg getting to thick at all?
Also have you done that thermostat mod to help warm up the veg?
x 8431
:cry:
Yep, it's a pump-off job. And an armour-off job as well :(
I have a seal set and will happily do the job for you Xac but one thing I will not do for all the ducks in the river Lovat is to do the dearmouring bit.
Pro-tem I can lend you a fully mechanical pump whilst we do yours.
For reasons that will soon be revealed, I am currently very heavily committed to things that will impact my time. Hence for apparantly being a bit quiet on here recently... Much is going on behind the scenes though.
Xaccers
x 188
KP wrote:Sorry to hear its the pump Xac :(
I think it's just old age really, with the added thickness of the veg.
I have done about 30K on 100% so far.
I could swap it with the pump from the LX Jim.
DIY sphere tool
x 8431
We can always borrow the pump off the LX Xac. And you know the immobiliser code for it.
You'll need a puller...
Xaccers
x 188
CitroJim wrote:We can always borrow the pump off the LX Xac. And you know the immobiliser code for it.
Well, I'm free for the foreseable future as of Monday so I've got plenty of time to get things sorted.
Having the pump off would make changing the glow plugs easier, and it'll give me a chance to put the bolt into the induction pipe bracket to stop it rattling :D
Actually, I have an idea for getting Juliet back on the road with her exhaust.
Just need to find somewhere that can chop the longer connection pipe off the front of the old exhaust and weld it in place on the new one.
DIY sphere tool
x 8431
Xac wrote:Well, I'm free for the foreseable future as of Monday so I've got plenty of time to get things sorted.
Oh no :cry: :cry: :cry: Speak to me on that subject at some point....
Xaccers
x 188
If I can get juliet back on the road, then Cassy can be sans-pump for however long it needs and I won't need to do multiple pump swaps.
DIY sphere tool
x 8431
Xac wrote:If I can get juliet back on the road, then Cassy can be sans-pump for however long it needs and I won't need to do multiple pump swaps.
How'd you fancy a double matrix job then? Juliet and my V6 :wink:
Xaccers
x 188
Sounds good to me :D
DIY sphere tool
KP
x 27
Unread post by KP »
2 matrix's and 2 pumps.... i dont envy you guys at all.....
Xaccers
x 188
KP wrote:2 matrix's and 2 pumps.... i dont envy you guys at all.....
Well if I can get Juliet back on the road (just needs the exhaust and heater matrix) then I don't need to put a spare pump on Cassy while hers is being repaired :)
DIY sphere tool
Xaccers
x 188
Well, I have some good news.
After fitting the right pipe rather than the hose pipe which the jubilee clip just wouldn't seal properly at the pump, my power steering troubles have gone (time to check Juliet's pipe as her steering is heavy unless the revs are above idle).
Also, there's no puddle under Cassy, so I'm thinking that rather than it being veg pouring out of the leaking pump (which is definitely leaking), it was actually LHM running down the back of the HP, mixing with the veg and dripping all over the road.
DIY sphere tool
