Hi new to this forum hope someone can help.
zx 1.9 deisel non turbo. Since adding deisel fuel cleaner it has been erratic with short surges of acceleration when accelerating from standstill and one day of turbo like acceleration.
thanks ron
zx deisel acceleration surge
- x 8394
Hi Ron and welcome to the forum
Firstly, I'd replace your fuel filter as the cleaner may have disturbed crud in the tank and now it is partially plugging the filter.
What pump is your engine fitted with as that can have a significant bearing on the symptoms you have. If you cannot fully tell if it is a Bosch or Lucas, pop a picture of it up we can then positively identify it.
Ronjo
racing zx
Hi Jim, Thanks for suggestion, I changed filter about 3 months ago had a problem on starting, seals not made but cured it, pump is a lucas, iunderstand there is not much you can do with them, but all info will be welcome, and i will change filter again. Thanks Ron.CitroJim wrote:Hi Ron and welcome to the forum![]()
- x 1240
Hi Ron
If the filter is OK sounds as though you have an air leak, your course of action depends, as Jim says on which pump you have, if its a bosch, for some inexplicable reason the leak offs are connected to the fuel so any leak there will allow air into the pump, check and see if there ar any fuel leaks, otherwise it could be any where, fitting a section of clear plastic tube near to the pump intake will help.
- x 1240
Ronjo
