using lexia proxia
citrov6
Unread post by citrov6 »
well, i will look in torents for PPS
Love my black v6 xant - only one with cream coloured leather too!
cachaciero
x 9
Unread post by cachaciero »
Hmmm....! Very interesting most of those pages look very familiar BUT I cannot record parameters from engine ECU.
Now question is this model dependant, this was obtained from a Mk2 C5 so it would be interesting to know Citronel if you can get the same graph from a Mk1 C5 or a Xantia?
cachaciero
citronel
Unread post by citronel »
At this moment I did not had the chance to connect my interface to a C5-I or Xantia...
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
The amount of information available on a Lexia depends on what car its being used on, the general rule is the later the car the greater the information, for instance on a S1 Xantia the information is relatively basic compared with a S2 Xantia which in turn is very basic compared with a Multiplexed car such as a C5 or Picasso where you can also alter/add programming features for car options such as cruise control.
On my Lexia 2 when testing a particular component by way of an actuator test if there is an Info Rapid (service bulletin) published, that will also be displayed following the test. Do the Chinese Lexias have the same facility?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citronel
Chinese Lexia it is only the HW interface, sw it is original Lexia3 sw.
till Lexia3 v42 if you have installed latest info/schematics CD then you will have all service bulletins and other info.
from v43, 44, 45 looks like Cit migrate to online server information for diagram and infodiag, they also supplied solution to diagrams checking offline under the name SDRE.
I try to attach Lexia info magazine 36-45 here:
"http://www.phones-direct.ro/public/Citroen Lexia/Lexia mag.zip"
citrov6
found cd45 and keygen. don't know how to use keygen yet but i will work on it. so far i get this message, i'm not computer savvy enough to understand what to do about it. someone with better understanding will probably understand this straight away
'windows cannot access the specified drive, path or file. you may not have the appropriate permissions to access the item'
Sl4yer
Unread post by Sl4yer »
citrov6 wrote:found cd45 and keygen. don't know how to use keygen yet but i will work on it. so far i get this message, i'm not computer savvy enough to understand what to do about it. someone with better understanding will probably understand this straight away
Sounds like you're using Vista, and maybe trying to install from a .zip file without extracting it first. May be wrong though, sorry if I'm insulting you intelligence with my reply.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
citrov6
its ok, i don't spend enough time with computers so i don't know them that well.
i'm on xp
it was in .rar form i opened it to an executeable but i think my security is blocking it somehow , so i tried to start it in safe mode, but it didn't want to boot up in safe mode.
i suppose this is something i will have to spend more time on to learn about
thanks
Sl4yer
Ah, OK. Probably the same problem. Have you extracted all the files in the .rar archive to your computer? You should have a file on your computer accessible from My Computer which looks something like this:
You can then run the instlex3.exe file to install.
2008 Mazda RX-8 231
citrov6
yea, lexia cd45 itself extracted fine. however it needs the pps2000 keygen so that it will work. and that is where i get the messages.
i got cd42 of ebay and that just installed and worked fine no keygen needed. i may go back to that if this doesn't work. cd42 is the only version i have ever tried
thanks
