Xantia Air-Con Bypass
hilldweller
Unread post by hilldweller »
Hi All
My timing belt has become rather frayed thanks to a stuck air-con unit. I noticed in the Haynes manual that the non-air con model looks identical except for the bolted on unit.
Anyone know if it's possible to bypass the unit with a belt from a non-air con model? I don't use the aircon and don't fancy having to buy the unit to keep the car running.
My Xantia is a 1.9td (1998 model).
As always thanks for any advice. :)
John
Xaccers
x 188
Unread post by Xaccers »
The quickest way, unless someone pops up with a link to the thread that's covered this before, and also the belt length you need, would be to use some string to map out the path the new belt will go (ensuring all pulleys turn the right way), and then measure the string.
That's what we did with Teh_Agent's when his compressor burst into flames.
DIY sphere tool
Old-Guy
x 26
Unread post by Old-Guy »
Just a small point that may save some confusion: you mean the auxiliary drive belt (multi-vee) not the timing belt (toothed and hidden under the plastic cover immediately beside the auxiliary belt.
hilldweller
Apologies, yes I do mean the aux drive belt.
Krede
Unread post by Krede »
I would try to come up with a way to get the pully on the compressor moving again... are you sure you cant get the clutch to release ?
Xantia 2.0 Hdi , Talbot Matra Murena 2.2(fuel injected ;) )
hilldweller
I'm not a mechanic, it's in the hands of someone I know who is. I want to make sure he's paid for his efforts but if there's some way I can cheapen the process then that'd be better - especially as I don't use the aircon!
MikeT
x 232
Unread post by MikeT »
I made a post of my belt routing which was fitted to by-pass the air-con. If you can find it, I think it has the belt measurement too.
It's not the solution I would have taken as that was done 7 years ago and I suspect the whole A/C is rotten to the core now. I get a duststorm of what I suspect to be aluminium corroded particles when the blowers come up :roll:
Not an ideal angle/view but it should give some pointers....
Click to Enlarge
Brigsygtt
Unread post by Brigsygtt »
Route the belt as per Mikes pic, i used an 1150mm 6pk for a citroen zx derv with pas & it fits a treat.
Have been running this setup for a couple of thousand miles with no probs 8)
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
hilldweller
That's great info, guys, thanks a million!
I'll print the pic off at work and pass on the belt info to my mechanic!
I found the link: http://frenchcarforum.co.uk/forum/viewt ... highlight=
Using a 1153 belt, so that confirms the zx belt measurement, too. :)
MikeT - so do you get dust just by turning on the fans??
MikeT
x 232
hilldweller wrote:MikeT - so do you get dust just by turning on the fans??
I don't have the car on the road so it's not used regularly but each time the blowers kick in (even on the slowest setting) there is a brief "snowstorm". Maybe that will reduce/disappear when regularly used.
I'm not certain it's the result of the A/C bypass (done in 2002) but I can't think what else it might be.
x 94
Unread post by citronut »
maybe you have meeeeses or is it mooooses in you polen filter Mike, and there nestting there, just check next time you use the blower to see if there is any tinny black bits in with the snowstorm, then you will know its mice
regards malcolm
scratcher
x 3
Unread post by scratcher »
I have a spare air-con compressor which is free to good home. Kettering area Northants. Model no. 1135253 Harrison.
x 94
Scratcher i would be interested in your pump, but how do i tell the diferance and what type my car has
regards malcolm
x 94
scratcher
pm sent
regards malcolm
scratcher
x 3
citronut wrote:Scratcher i would be interested in your pump, but how do i tell the diferance and what type my car has
regards malcolm
I have quoted the number on the compressor , if you get under the car and wipe all the Sh1 T off you should find the relavent numbers. It is very heavy so really needs to be collected
Xantia vsx
GSA 1300
Previous AMI8 estate
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
