Hi ,
Can anybody tell me , If any , what extras would the Temptation model have ?
Or is it the basic model .
thanks
Terry .
Xantia diesel Temptation
red_dwarfers
- x 58
Right. I originally had the idea that Sensation, Temptation and Athena were the S1 LX, SX and VSX respectively with a variety of optional extras chucked in for free as standard when the S2 was introduced to get rid of the old stock. However, I could have sworn that I have seen a Temptation 2 on N/P plate a couple of times which completely contradicts my theory, unless the S/T trims were upped spec pre-96 LX/SX's aswell?
Based on the above, I would say that the temptation trim level would have all round leccy windows, leccy heater mirrors, body coloured bumpers, front fog lights, ABS, air con and possibly sun roof....not promising anything though
Im probably creating more questions than answers
Kev
'19 C4 Cactus 130 Flair
- x 8378
Not at all Kevred_dwarfers wrote: Im probably creating more questions than answers
Well, just to add to the confusion, my S1 2.1TD is a Desire according to the V5. I can't confirm that as it began life as a commercial vehicle and was de-badged to make way for decals on the tailgate.
In reality it's an SX with a few small additions. In mine that was Activa Alloys and Alcantara (long gone, worn out) seats. Mine has the LX-style black bumpers and rubbing strips but has colour-coded mirrors
I believe that a Temptation is in fact an LX but with all the bits to make it an SX such as electric windows all round.
I've not come across a Sensation. An S2 model perhaps?
Ross_K
- x 110
Parkers says the LX is the same as the Temptation/Stateside/Sensation/Forte/Dimension. Whether or not you got rear electric windows and the like probably depended on the mood of whoever was screwing the car together on that particular day...
The Desire is apparently the same as an SX.
I don't know where the Athena fits in to the scheme of things... Possibly same as a VSX as Kev says.
I also never knew there was an X, with a meaner spec than the LX (if that's possible - must have been a fleet spec)
red_dwarfers
- x 58
Thats a point, the only Sensation I've come across (
) is MikeT's S2, but he doesn't have ABS but has air con? Mike?
Maybe the Estates were badged differently again.
This will certainly be an interesting topic as you say (Hi) Jack
EDIT to incorporate Ross's post:
Ahh Dimension...that rings a bell, I think that N/P reg Xant I saw was a dimension not....the other one
I imagine that LX was the fleet spec. I've only seen one X spec (presumably doesn't have a badge on the back) a chap a couple of miles away who has an S2 with non body coloured bumpers, no air con and I don't think he had ABS.
Kev
admiral51
- (Donor 2026)
- x 391
MikeT
- x 232
My first TD was an R-reg S1 Temptation. It had only front electric windows, electric mirrors, colour-coded bumpers/mirror covers, steel wheels, A/C, ABS, alcantra seats, driver airbag.
My next TD is an R-reg S2 Sensation. It only has front electric windows, electric mirrors, colour-coded bumpers/mirror covers, steel wheels, A/C, CD changer, drivers airbag.
That's off the top of my head so there may be omissions.
MikeT
- x 232
From citroen service using the vin, this is the S1 Temptation spec in all it's glory....
Vehicle family XANTIA
AS RPO No 07499 CJ 1 0308
Guarantee Start Date 01/01/1990
Engine serial number 10 CUCP 4002788
Gearbox serial number 20 CH97 8593221
OPB D00G
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XANTIA
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL LEVEL 2
ENGINE TURBO DIESEL XUD9TE
TRANSMISSION BVM5
INTERIOR TRIM TYPE CANANGA VELVET "FV"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BE3 L
OTHER BADGE TURBO D
OTHER BADGE, " MISC. " NO ADDITIONAL BADGE
BADGE XANTIA BADGE
TRIM LEVEL LEVEL 2
STEERING POWER STEERING
FUEL SUPPLY TURBO-INJECTION EXCHANGER
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF NO FUEL FEED CUT-OFF
REGULATION 70/221 (FUEL LEAKS) WITH NON-RETURN VALVE
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 15 X 64
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 185X65X15 H TYRES
WHEELS FITTED 5,5 RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX BE3
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
TRACTION CONTROL WITHOUT ANTISLIPPING
HYDRAULIC STOP WITH HYDRAULIC STOP
HYDRAULIC PUMP PRESS PUMP 6+2 + NON-SINKING
REAR SUSPENSION SPHERE IMPROVED RR SUSP SPHERE
ACTIVE ANTI-ROLL W/O ACTIVE ANTI-ROLL
FRONT SUSPENSION SPHERE DESMOPAN WITH TALC
MAIN ACCUMULATOR SPHERE TALC DESMOPAN ACCUMULATOR SPHERE
STEERING TRAVEL STEERING MECHANISM TRAVEL 74,3
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
HORNS HORNS-HARMONY
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
WHEEL EMBELLISHER (STYLE) BARCELONE STYLE 5 HOLES 15 INCHES
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT INDEXED REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING BULKHEAD + BONNET SOUND-PROOFING
LIGHT CLEAR GLASS
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BODY COLOUR SC CAR
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES RRVIEW MIRROR CASING BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
REAR HEAD RESTRAINT JOINTED REAR HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITH REAR ARMREST
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITH LUGGAGE COVER
REAR SEATBELT REAR RETRACT BELT + ABDOMINAL RETRACT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
DASHBOARD EQUIPMENT FACIA PANEL WITHOUT WOOD
MISC. INT. LAMPS MAP READING LAMP
DOOR TRIM DOOR PANEL WITHOUT WOOD DECOR
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER MOUNTING 6 LOUDSPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) W/O INSULATION (CURTAIN,SUN VIS SCR,SUN ROOF)
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT SPACER PASSENGER SIDE
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVERS LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT W/O PASSENGER LUMBAR ADJUSTMNT
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM + PLIP
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER'S WINDOW LIFT SEQUENTIAL DRIVER'S ELECTRIC WINDOW
PASSENGER'S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
COURTESY MIRROR DRIV OCCULT+PASS W/O LIGHTING
OIL PRESSURE GAUGE WITHOUT OIL PRESSURE GAUGE
OIL GAUGE OIL LEVEL WARNING INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 2 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
PASSENGER AIRBAG NO PASSENGER AIRBAG
IGNITION CODE (OPERATION) STD CODED IGNITION
RADIO RECEIVER PERFORMANCE 2 RDS RADIO
REFRIGERATION REGULAR AIR CONDITIONNING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER'S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
AIR CON./TEMPERATURE REGULATION WITH SIMPLE REGULATION AIRCON/TEMP
STORAGE (OTHERS) LOWER SETTING BOX FR AND RE DOORS
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
REAR CARPET REAR TUFTED TYPE CARPET F112
CARPET TUFTED CARPET "F112"
LIGHTING TIMER ADJUSTABLE TIMER
EXTERIOR TEMPERATURE (SCALE) WITHOUT EXTERIOR TEMPERATURE GAUGE
SWITCH CODED IGNITION
WATER TEMP INDICATOR COOLANT GAUGE + LED + PREWARNING
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH + AIRBAG
ALTERNATOR ALTERNATOR 120 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
LIGHT CLEAR GLASS
COUNTRY TYPE (GB)
SPECIAL SPECIFICATION ATHENA
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE LEFT HAND DRIVE
SIDE IMPACTS DOOR WITH REINFORCEMENT
SURFACE CONDITIONS GOOD TERRAIN
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
POWER VARIATION (FISCAL RATING) W/O TREASURY RATING VARIATION
OPB D00G
PRODUCT TYPE CAR
TRIM LEVEL LEVEL 2
TRANSMISSION BVM5
OTHER BADGE TURBO D
BADGE XANTIA BADGE
TRIM LEVEL LEVEL 2
FUEL DIESEL FUEL
TRANSMISSION BVM5
ABS WITH ABS BRAKES
HORNS HORNS-HARMONY
LIGHT CLEAR GLASS
SUN ROOF FIXED ROOF
HORNS HORNS-HARMONY
LIGHT CLEAR GLASS
COUNTRY TYPE (GB)
MikeT
- x 232
And for the S2 Sensation...
Vehicle family XANTIA II
AS RPO No 07859 CJ 1 0018
Engine serial number 10 CUKD 6002493
Gearbox serial number 20 TA59 9597859
OPB A02D
NRE e2*93/81*0124*02
PRODUCT TYPE CAR
VEHICLE FAMILY XANTIA R
TRIM LEVEL SX
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
INTERIOR TRIM TYPE OMEGA CLOTH + "LM" MOLLETON
UPHOLSTERY COLOUR "FZ"
ENGINE (TYPE) XU/XUD
OTHER BADGE TURBO D
BADGE XANTIA BADGE
TRIM LEVEL SX
SPEEDOMETER DRIVE TACHO TORQUE 22X18
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
CATALYTIC CONVERTER 3 PARTS CATALYST
FAN 2 FANS , 2 RATES , IMPROVED
TRANSMISSION BVM5
WHEEL STYLE STEEL WHEEL
TYRE (SIZE, TYPE) 185X65X15 T TYRES
ABS W/O ABS BRAKES
HYDRAULIC STOP WITHOUT HYDRAULIC STOP
REAR SUSPENSION SPHERE RR SUSP SPHERE DESMOPAN TALC
FRONT SUSPENSION SPHERE FR SUSP SPHERE DESMOPAN TALC
HORNS HORN STANDARD
WHEEL EMBELLISHER (STYLE) BACCARAT STYLE 8 HOLES 15 INCHES
FRONT PANEL BLANK SEMI-CLOSED GRILLE + OPEN BUMPER
BUMPER BODY COLOUR SINGLE NOZZLE
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SUN ROOF FIXED ROOF
REAR SEATBELT INERTIA REEL+STATIC LAP
MISC. INT. LAMPS MAP READING LIGHT DRIV+PASS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER LUMBAR ADJUSTMENT
COMPACT DISC MOUNTING COMPACT DISC
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
FRONT LATERAL AIRBAG NO LATERAL AIR BAG
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
RADIO RECEIVER PERFORMANCE 3 RDS RADIO
REFRIGERATION AIR CONDITIONNING
RADIO HOUSING WITHOUT RADIO LOCATION HOUSING
CARPET CARPET F470
EXTERIOR TEMPERATURE (SCALE) EXT TEMP INDICATOR CELSIUS
SWITCH ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR WATER TEMP INDIC +RED TELLTALE
FLOOR MAT WITH MAT
HORNS HORN STANDARD
CEN. LOCKING REM CONTROL FREQUENCY 433 92 MHZ HETERODYNE
COUNTRY TYPE (GB)
RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
OPB A02D
PRODUCT TYPE CAR
TRIM LEVEL SX
TRANSMISSION BVM5
OTHER BADGE TURBO D
BADGE XANTIA BADGE
TRIM LEVEL SX
FUEL DIESEL FUEL
TRANSMISSION BVM5
ABS W/O ABS BRAKES
HORNS HORN STANDARD
SUN ROOF FIXED ROOF
CARPET CARPET F470
FLOOR MAT WITH MAT
HORNS HORN STANDARD
COUNTRY TYPE (GB)
RichG
Xaccers
- x 188
I'm pretty sure Dex's log book says Desire II and he's a S1 too.MikeT wrote:It read TEMP II on the logbook of my S1
DIY sphere tool
DIY sphere tool
MikeT
- x 232
Chevron Terry
Xantia Temptation
Hi ,
I have just been mailed the pictures of the car [ Temptation ]
The bumpers and trim are black and not colour coded .
Steel wheels , plastic trim .
Cannot see Sunroof .
The pictures are of the outside of the car only .
Terry .
Terry .
MikeT
- x 232
