Fault codes relating to my AL4
asav
Unread post by asav »
Nice1 Jim...emailed Ya.
x 8412
asav wrote:Nice1 Jim...emailed Ya.
Received and suitablly replied...
Do also check the wiring harnesses between the gearbox and ECU for damage.
paulhelliwell2
Re: Fault codes relating to my AL4
Unread post by paulhelliwell2 »
i have the following error codes on my bva-al4 gearbox any help please
63-66-71-76 there only temp faults?
x 1055
Unread post by wheeler »
See this post from another forum > http://www.cxoc.net/index.php?topic=162 ... #msg220784" onclick="window.open(this.href);return false;
cachaciero
x 9
Re:
Unread post by cachaciero »
CitroJim wrote:All the problems point to a dodgy electrical connection between the ECU and the gearbox.
I'd remove the battery and then break, check and clean where necessary, the connector to the gearbox ECU and the connector onto the transmission as a first step. If this does not help, the finger of suspecion must point to the multifunction switch, given the last error code. It is certainly electrical.
I have some generic circuits of ther AL4 and heaps of other useful information besides. I cannot post it as it's all in a big PDF file. If you want to email me, I'll send you the document in a reply email.
Having this document will allow further fault finding.
You could go onto the citroenservice web site and for the princely sum of 4.5 euro's download the schematics for your particular car, but Jim's data is probably better value for money :-)
EDIT
As an afterthought both EV's shorted to positive could indicate a poor ground return related to them.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
