Rad Flush
Chevron Terry
Rad Flush
Unread post by Chevron Terry »
I have just bought some " Proper " Antifreeze from my local Citroen dealer . [ so they tell me ].
Iam going to flush and refill the Rad .
Do I need to flush and change the engine block as well ?
Terry .
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It never hurts to do a full chemical flush of the cooling system.
Be warned it may hasten any leaks of the heater core.
x 1942
addo wrote:It never hurts to do a full chemical flush of the cooling system.
So it does sometimes hurt then... :lol:
x 8391
On a well maintained system where the coolant has been changed regularly and maintained at correct strength, there should be no need of a flush at all.
In all the engines and cooling components I've stripped, never have I seen a situation where a flush would be warranted.
The only exception was my own V6 that had been contaminated with rather a lot of an unknown brand of radseal. A flush of the block with fresh water did for that...
x 5674
It should be OK to just drain and refill.
However...
If the brand/type of antifreeze previously used was imiscible with the recommended Citroen antifreeze then it may gel up in places and cause blockages, always in the worst of places of course.
As Jim says, it is not really required under normal circumstances but here you could have an unknown variable.
Personally I'd flush the whole system and stick some Forte Cooling System Conditioner (way down the page) that is indicated as being not only compatible but desireable.
Another link. My computer makes a huge mess of this page, you may be lucky.
x 1942
myglaren wrote:My computer makes a huge mess of this page, you may be lucky.
It's not you at fault.
Whoever wrote the page leant on the hash key when they were writing the description!
x 5674
Didn't see that and presumed it was crafted for IE. Thanks :)
