Wanting to fit a bigger intercooler, and an EBC.
XantiaMan
x 18
Unread post by XantiaMan »
One of the weak points on my car is the intercooler set up. It sandwiched between the rad and air con rad, so suffers alot from heat soak. Because the air con rad sits in of it, this means its airflow will be restricted aswell.
So i had a good look today, but cannot see an easy solution to relocating and fitting a more efficient core.
If the air con rad was removed, no problem, but i do not want to do away with this luxury which is essential on those heatwave days.
I know not many people have bothered modifying the Activa CT lump, prefering to slate it saying its too slow out the box, but i know it is a good engine with a huge potential for power if the right ingredients were added.
Has anyone fitted a bigger intercooler to an Activa? And if so, was it an A/C model (early ones were not) so it would be alot easier on these.
I also had a look at the best place to route through the wiring loom for my electronic boost controller, but i couldnt see any logical path from the engine bay. People who have removed engines or dashes will know better than myself, but are there are blanking grommets or other areas that could be accessed without too much trouble to route a wire and vacuum hose through?
The boost on mine had dropped a little, was only running 10psi so i have tweaked this back up but the closer it gets to 14psi, the higher the chance of it spiking and hitting the boost cut which then triggers a fault code. So, fitting the EBC will reduce this risk and keep my boost optimum, it will also help a little with response as you can trim the gain.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
Xaccers
x 186
Unread post by Xaccers »
I'm intreagued, how do you know it suffers from heat soak rather than actually being big enough with enough air flow to cope with the aircon rad in front?
What's the temperature difference you're getting between the air into the cooler and the air out?
DIY sphere tool
XantiaMan
x 18
Xac wrote:I'm intreagued, how do you know it suffers from heat soak rather than actually being big enough with enough air flow to cope with the aircon rad in front?
Just knowing from experience, a inlet temp gauge would prove it, but the power really drops after a few hard runs, knowing that the turbo is tiny for the job, it will definatly be running flat out at 12-13psi.
Sitting in traffic for a while or just letting it idle for a long time and then driving you can also feel the difference. At night time performance is vastly improved too, the same could be said for a lot of turbocharged vehicles that like a denser charge, but the difference is really huge.
In comparison, my Maestro which has an huge intercooler with a core twice as thick and sits in front of the rad, goes consistantly well after some silly action. Of course, the big turbo itself helps with the inlet charge not getting as hot.
I think if the air con rad wasnt in the way, and some subtle improvements made to airflow, that would make a subtle difference.
2017 Fiesta ST
Brigsygtt
Unread post by Brigsygtt »
Might be worth fitting an act temp gauge before condemning the o.e setup mate. Probably need to ditch the aircon rad to fit a decent sized i.c in there too?
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
Sl4yer
Unread post by Sl4yer »
IIRC the Lexia has an air temperature reading, which I presume (from some of the VERY high values recorded) is the inlet temperature.
What would be a good inlet temperature? Is there any way to mount a water spray on the Xantia intercooler?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
XantiaMan
x 18
Sl4yer wrote:IIRC the Lexia has an air temperature reading, which I presume (from some of the VERY high values recorded) is the inlet temperature.
Water sprays don't work very well, I tried a set up years ago on the maestro. Can you remember what figures they were?
A good intercooler set up won't go over 45 c. If I saw anything over 60c on boost (I reckon it could go higher!) Then quite a bit of power is being lost, and higher inlet temps also put the pistons at risk due to increased risk of detonation.
I would like to see temps in the 30's, that does depend on the ambient temperature though.
2017 Fiesta ST
XantiaMan
x 18
Still unsure about where to route the wiring for my EBC?
2017 Fiesta ST
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
I was going to :oops: :oops: :oops: myself and suggest the piggy backing of a wire that goes into the main loom connector under the scuttle drivers side(uk) until i saw the bit about the vacuum pipe :oops:
Probably a really silly idea but could you find a way to route the vacuum pipe through the gearstick linkage area
Colin
Sl4yer
XantiaMan583 wrote:Can you remember what figures they were?
54C rings a bell, although I can't remember if that was after a drive or on start up. Sounds more than is ideal in any case. I'll get around to having a proper check some time.
2008 Mazda RX-8 231
XantiaMan
x 18
Yes that would be good if you could.
Colin, isnt the scuttle glued down? I know the wipers would have to be removed at least to get access.
I may cheat a little, and drop it down the A pillar, through the drivers door loom and then under the carpet to meet up with the centre console. Planning to do it this weekend, hopefully.
2017 Fiesta ST
Xaccers
x 186
Check behind the carpet in the passenger foot well.
When Jim had his up there looked like some plugged holes which I'd imagine were for LHD versions.
That might work as an access point.
DIY sphere tool
XantiaMan
x 18
Xac wrote:Check behind the carpet in the passenger foot well.
I'll have a gander, failing that i may use the bonnet cable grommet and squeeze it through there.
2017 Fiesta ST
KP
x 27
Unread post by KP »
Your choice really is limited as even an all alloy or copper IC will not herald any gains. Some IC sprays are quite good the CO2 ones and the ones that user ultrafine misters like those found in Aquamist kits are good.
Why not go for an Aquamist kit and see what happens?
The other option is to fit a Charge Cooler setup and maybe use the IC as the cooling medium to dump the heat to.
Really you could do away with the IC, and use the AC, by runing something along the lines of a CC setup but using the heat dump as the AC system instead???
admiral51
(Donor 2026)
x 391
Sorry Gareth didnt make myself clear :oops: :oops:
Didnt know if you could use one of the existing wires in the main loom that may not be in use as these will already fused etc and that way you could connect from inside the cabin via the fuse box.
Not sure whether this will help you or not but in this Topic Andmcit has posted the bulhead connections for the main loom may be something or nothing :)
But you are correct in the fact the wipers and scuttle need to come out to gain access not sure if you could trace backwards without needing to delve under the scuttle
Colin
