Electrical issues
Toby_HDi
x 3
Unread post by Toby_HDi »
Well the battery is on charge now so see what difference that makes. I did notice that one cell was low on electrolyte so topped that up before charging, hopefully that'll solve the problem of the non starting.
Still not sure on the speedo though
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 1489
Toby,
If the batt is really only reading 10V just after coming off charge then it is cactus most likely - this is suggestive of a completely kaput cell, and a bit of distilled water is not going to fix it.... :o
As for the speedo - no idea, but you used to own a French car, should be used to Gallic shrugs like that :wink:
Toby_HDi
x 3
It was reading 10v before a charge. So hopefully the charge and top up will help.
Indeed I am, it is annoying though as I have the week off work this week and it means I can't really go for a drive without a speedo.
Toby
Previous:
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Toby_HDi wrote:I did notice that one cell was low on electrolyte so topped that up before charging, hopefully that'll solve the problem of the non starting.
In my experience if a battery cell needs topping up its a pretty good indicator that the cell is knackered.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi Toby
Just had a look on tinterweb and had a gander at your posts on the VXON forum :) :)
I see that you have changed the cluster/dials etc and you still have the same problem :( :(
Have also found This Site
Maybe nothing like the connections you have but not sure if you had seen it :) :)
Colin
Toby_HDi
x 3
Well I've charged the battery and its still dead so thats one problem methinks. As Richard says, maybe once they need topping up they are dead already.
Thanks for that Colin. I don't believe thats the problem as all seems fine. Maybe the dead battery just kills something in the clocks and so on changing the circuit board it worked until the battery killed it again.
Toby
Previous:
x 5672
Toby_HDi wrote:Well I've charged the battery and its still dead so thats one problem methinks. As Richard says, maybe once they need topping up they are dead already.
More often than not, but not always.
My neighbour's SEAT wouldn't start.
Checked the battery, practically bone dry.
Took it out of the car, filled it with H²O, charged it for 48 hours and it was fine for another two years when they gave the car to a relative.
They had never once checked the battery in the three years they had owned the car :shock:
x 5672
No, not a maintenance free or low maintenance, just bog standard battery.
Toby_HDi
x 3
Well after all that it was the battery, bought a new one today that is slightly beefier than the old one (68AH rather than 54AH) and the car starts now, also sorted the speedo too.
Thanks to everyone for your help, especially considering it isn't French :oops: :roll:
Toby
Previous:
admiral51
(Donor 2026)
x 391
Its nice when its a simple fix :D :D
Once a green blood always a green blood :lol: :lol:
Colin
Bren
Unread post by Bren »
Toby, glad you sorted your problem - batteries can cause all sorts of strange problems. My dad's old vectra (now dead) was running fine until he stopped for a news paper - he came out and it would'nt start. Dead Battery was the problem.
Batteries are much more powerful these days than in the 60's and 70's, they are also much more compact, as a consequence when they fail they do so without warning!
My Xantia has a citroen item, the levels are checked and it gets the occasional trickle charge, it will be seven years old this year.
I always fancied an omega, I have had a senator and a royale saloon, however I have heard too many horror stories. Has yours been ok?
96'Xantia 1.9 td estate
93'gsxr- 750
85' Rover 3500 (work in progress)
Toby_HDi
x 3
Indeed, this one went without warning too!
Well I actually have 2. One is a 2.5 Auto, that one is on loan at the moment and have been told its running faultlessly. Once another car has been sourced I shall be getting that one back and selling it on
The one I use is a 3.0 Manual Elite. Mechanically it is fine, I do have a slight intermittant issue but hopefully that will be sorted once I have got it hooked up to a Tech 2. Only thing that annoys me is it is slightly rough around the edges, bits of trim, missing bolts etc etc. I'm sure it wouldn't bother most people but me it does :lol: Thats not something that I can put down to it being a questionable car, just the previous owner not looking after it. I did get it cheap though. A few issues but what car doesn't? Mainly cosmetic anyway
So far so good really.
I'm assuming you have heard stories of cambelt failures? What else?
If you actually are after one, am always happy to help answer any questions that I may be able to.
Toby
Previous:
Bren
As you said Toby, cambelt failures, head gasket / oil cooler probs plus other electrical problems - I have also seen a few scabby ones. Having said that I would chance a 2.2 diesel - the v6's are too thirsty for my liking
93'gsxr- 750
