PAS Pump Failure Symptoms
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Yep - you guessed it - Paris again. I'm wondering if the pump is past it's best.
What are typical signs that an 18 year old PAS pump is on the way out? Do they load up the motor unevenly?
There is no appreciable fluid loss, or metallic noise, but the pulley is clearly skidding on the belt.
x 94
Unread post by citronut »
tighten the belt
regards malcolm
x 5672
Nice post count Malcolm :)
addo
x 95
Glad to see my irreverence gets the comebacks and topic sprawl it deserves. :lol:
I will be replacing the belt - got a Dayco 545mm one - PSA specify 530mm and the present unit is 560mm (currently at the end of tensioner slot). Waiting for the liquid sunshine to dry out a little.
Regards, Adam.
x 94
Adam wrote
"currently at the end of tensioner slot"
there y go you answerd the question your self Adam,
i would get the smallest belt which will just about go on, otherwise you will runn out of adjustment prematuraly
" Waiting for the liquid sunshine"
we just had some of that day before yesterday (monsoon like)
in the sunny south of UK
regards malcolm
ps.
Steve wrote
"Nice post count Malcolm"
i can only count 9.5 the nooooo since my run in with Chris Salters DS TEA HE
x 5672
We are members of the same club, Malcolm :)
