Socket size for 306 hub.
Happy
Unread post by Happy »
Can anyone please tell me what size socket that i would need to remove the large nut on the hub on the rear of a 306. Thank you all.
x 94
Unread post by citronut »
i cant remember exactly but im sure its either 30mm or 32mm
regards malcolm
uncle buck
x 10
Unread post by uncle buck »
It was a 32mm on my ZX.
Cheers.
2001 Xsara II 1.4 LX
Happy
uncle buck wrote:It was a 32mm on my ZX.
Cheers.
Thank you for the reply.
I tried a 32mm, But it is a lot bigger than that. I have not got a clue what size it can be then?
x 5644
I would check it on my son's 306 but unfortunately it went to Geneva yesterday and won't be back for a couple of weeks.
The irony with that is the car got there before him - he flew this afternoon :roll:
citroen7
Unread post by citroen7 »
try 36mm
x 94
try a 34mm then, i have never seen a 306 with a 36mm rear hub nut, front PSA hub nuts are quite often 36mm
regards malcolm
Happy
citronut wrote:try a 34mm then, i have never seen a 306 with a 36mm rear hub nut, front PSA hub nuts are quite often 36mm
regards malcolm
I will have a look tomorrow. Thank you for the reply, Much appreciated.
