Built in stereo
andy007
Built in stereo
Hi All
Does anyone know the specs for the integrated car stereo on an M reg Xantia please? Output.. ohms .. Connectivity etc...
The factory fit speakers were good but over time I have had to replace them, front only, but just want that extra something without turning the car into a night club.
It's the original stereo but I would like to 'enhance' the output performance. Have tried different speaker manufacturer's and after a certain level the sound gets distorted. Is there a universal facia that could fit the hole if I decided to change the stereo? I do love good sound when I am travelling.
Thanks in advance
Andy
Thanks in advance
Andy
Onlinemyglaren
- x 5676
I'd hazard a guess that you need a supplimentary amp. Lots of Watts doesn't necessarily equate with boy-racerism, distortion does equate with a lack of power and will eventually destroy your speakers.
It is the converse of what you would logically expect, too few Watts bad, too many Watts =fine.
A sweeping generalisation I admit but essentially holds true.
On the practical side I have never dabbled with ICE so can't give any practical advice. My vice is home stereo.
admiral51
- (Donor 2026)
- x 392
lolingram
- RIP 2010
As Myglaren says, this is due to 'clipping' of the audio waveform, due to lack of dynamic power. This leads to near quare wave distortion, and burnt put speakers. More pure watts is better in this case!I'd hazard a guess that you need a supplimentary amp. Lots of Watts doesn't necessarily equate with boy-racerism, distortion does equate with a lack of power and will eventually destroy your speakers.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
Ross_K
- x 110
Re: Built in stereo
Autoleads FP-12-00 - you should be able to pick one up for a fiver on ebay:andy007 wrote:Is there a universal facia that could fit the hole if I decided to change the stereo? I do love good sound when I am travelling.
Thanks in advance
Andy
dieseldoggy
Personally i'd change head unit as pretty poor.the standard speakers are very good italian made.unless your going to spend a fair bit get some more of them.or put component speakers in.but have a look around as aftermarket speakers will lose you're bass end as their designed to work with other speakers ie subs to give you full range. you have two tweeters on top of dash also. yes you can get the adaptor from most places for them.it's an autoleads part. then it's pretty easy to change once you have contrived the bits out and installed adaptor.bit fiddly.the leads plug straight in and link up.depending on what unit you get? as some will still work with streering wheel controls! ive a blaupunkt dab one and you just buy add on which plugs in back then links up wires.citroens do make a could car for an install as OE stuff is quite large so can get something good to fill holes! i'd did door builds on my estate back door and have 6x9's in them. But you're head unit is week spot. pity you're not up this way i could show/do it for you no problem as done loads of installs. still got some kef uniQ's.
If i was buying new headunit now i'd be looking at something DAB able?
xantia 19td estate 96-7
reblack68
If you do get a DAB replace the aerial with the long type from a Renault or other French car of the era. Then simply connect the centres of the two antenna sockets by stuffing a piece of wire in. It sounds like a total bodge, mostly because it is, but my in-car DAB performs better than any other DAB (car or house) I've come across.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
lolingram
- RIP 2010
Bearing in mind that no other European country uses (nor likely to in the forseeable future) the UK/BBC DAB system, which is still far from perfection. The Beeb claimed at the outset that it would mean higher fidelity than FM analigue mon/stereo.If you do get a DAB replace the aerial with the long type from a Renault or other French car of the era. Then simply connect the centres of the two antenna sockets by stuffing a piece of wire in. It sounds like a total bodge, mostly because it is, but my in-car DAB performs better than any other DAB (car or house) I've come across.
The sad facts are that the Beeb often transmit in low Bit format, which is nowhere near the quality of Radio 3/4 FM. With a really good home FM tuner, the sound quality on FM can be staggeringly good (as long as the Beeb turn down the dynamic compression).
The only plus side(!) is that the government can flog off much of Band II.... sad how things are going to the dogs in UK. Once a really great country, but now the biggest police state in Europe, with little real democracy.
Previously...
Previously...
Ross_K
- x 110
Get with the times - DAB is old hat already.
3G internet access is getting (more) affordable so I think internet radio on the move will be the way to go in the next few years...
I've been messing around with >>> Resco Radio <<< on my phone connected to a Sony headunit via front the input jack. Quality is fine as long as you don't go mad listening to 128k audio streams. Coverage is hit and miss out in the sticks (as is the case with DAB), but for townies with unlimited data contracts it's an interesting possibility.
lolingram
- RIP 2010
Old hat is usually good in my experience over more years than I care to remember... analogue FM has served us very well indeed since the early 50's experimental transmissions from Wrotham. I built a receiver then, which produced serious HiFi to 15khz, and was a revelation. The eventual shutdown of this technolgy will be a body blow IMHO.Get with the times - DAB is old hat already. Very Happy
I live in Frogland, where there are no immediate plans to change, thank God. They can do what they like when I kick my clogs!
Previously...
Previously...
Xaccers
- x 188
If memory serves, DAB is based on 1982 technology.
It would be ok but our government has it in it's head that choice is what people want, to the detriment of everything else.
So they try to cram the bandwidth with as many rubbish stations as they can, reducing the bit rate of each so that in most cases, FM actually has higher quality sound.
The worry is they're talking about taking the national stations off FM, so no more Radio4 for me after 2012
DIY sphere tool
DIY sphere tool
lolingram
- RIP 2010
Exactly so. In my experience, DAB never sounded actually better than best quality FM Xac... FM is near to CD quality given good reception and an excellent home tuner. My Quad FM 66 tuner of 1980 technolgy still passes muster.Xac wrote: So they try to cram the bandwidth with as many rubbish stations as they can, reducing the bit rate of each so that in most cases, FM actually has higher quality sound.
Previously...
Previously...
lolingram
- RIP 2010
You can still listen to all BBC channels on FTA satellite (Eurobird @ 28.2ºE) in CD quality XacThe worry is they're talking about taking the national stations off FM, so no more Radio4 for me after 2012
Previously...
Previously...
