Since owning the car it has never worked so i have driven "by ear" and it seems rather conservatively
Once completed, I went out for a spin on the motorway using the rev counter to see how many revs the car was doing when i reached the maximum speed ive ever taken it (90mph)...it was just over 3000rpm.
Then i pushed a little harder
Once down to around 90mph and lower it stops....
Now normally id go for control arm bushes, but these tend to wobble under braking from high speed (which doesnt happen) or wheel balancing...but then that would happen before that speed. Driveshaft wear would also happen before that speed, and a knackered CV Joint would usually groan when the gas is lifted off and again even at lower speeds.
It is worthwhile saying that the box remained smooth and the engine seems smooth also...so im looking for someone who has experienced this before and found the cause....
If it cant be found, im not hugely bothered as i dont ever drive that fast or have any need to....i want my rev counter to work so i can strive for better economy.
Any ideas guys?
