c5 hdi clutch adjustment
sportingfiat
Unread post by sportingfiat »
is there any way to adjust/bleed the clutch on a 2.0 hdi c5?
sometimes seems to be catchin/ crunching going into 2nd/3rd
got a reciept for a new cluych approx 18k ago
x 8363
No adjustments on it at all sadly and not bleedable either :( Well, not easily anyway.
A crunch into third is not unusual on a MK2 and is something I put down to worn gearchage cables as these are different to the MK1s fitted with the ML5 'box and this problem never seems to occur on them.
I had this problem on my MK2 Activa and had a set of replacement cables to fit but the car was sold before I did the job and the cables went with it. I don't think the present owner has swapped them yet. Gareth?
sportingfiat
is there a bleed valve anywhere then ? ?
dont really know much about these hydraulic jobbies :(
x 8363
sportingfiat wrote:is there a bleed valve anywhere then ? ?
No, the whole hydraulic system is sealed for life :(
HDI Dave
x 3
Unread post by HDI Dave »
Sounds like my sealed system. There is actually a reservoir on the bulkhead.. and I had to take the clutch hydraulic pipe off the slave cylinder,hold it against it tightly,while the mrs bled from the pedal end:
http://www.frenchcarforum.co.uk/forum/v ... c&start=15
How could air have got in though?
Maybe it's just worn or gbox cables as Jim says.
1999 Xantia LX 2.0 HDI 110 Rusteration project...
XantiaMan
x 18
Unread post by XantiaMan »
Nope, still sitting in the roof of my garage. Does still crunch sometimes but moresore if its rushed, not a problem normally.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
