C5 2003 2.2 HDI Auto, had to come home today courtesy of the AA, they said Crankshaft Pully was on it's way out, is this just a matter of Aux belt off, undo Pully nut , pull pully off, new Pully on, inset nut ,torque up,replace Aux belt, or is it not that simple.
Any ideas for locking the Crankshaft so I can tighten the bolt, it is an Auto.
C5 Crankshaft Pully
acrowot
C5 Crankshaft Pully
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
- x 94
i think it will be one of them there dual mass pully's, in which case it will probably also have a D/M flywheel as well,
the pully isn't a problem as it will be as you say, but i have heard you are not ment to lock the crack by a lever into the starter ring gear with this type of flywheel,
regards malcolm
ps.
i also found GSF to be a lot cheaper than the dealers when i replaced this pully on a pissssscaso, they had two quality's i wpuld recomend you buy the higher priced one, because if this fails you risk the aux drive belt wormming its way into the cab belt houseing a reaping all kinds of expencive damage
regards malcolm
ps.
- x 1056
acrowot
Thanks for your replies, yes it is a dual mass pully,not sure about the flywheel, so it would seem I will have a problem locking the shaft for tightening, I will use the starter motor method for unbolting, is using the auto box park position a no no.
- x 1056
I don't think the auto has a DMF, dont think there would be any point ? Just to clarify, I dont mean using the timing pin locking hole to hold the flywheel, thats a definite no no . I mean using a screwdriver or similar on the actual ring gear teeth to hold it. That is if you can get to them easy enough, maybe need to take the starter out. There is no problem using the teeth on the ring gear to lock the flywheel even on a DMF as the ring gear is on the solid side of it. The proper citroen tool just jams the ring gear.
acrowot
Hi wheeler, thanks again for your reply, no I was not contemplating locking the pully using the timing pin. I was wondering if the park position on the auto box that I understand locks the diff with pins in the park position and applying the brake would enable the nut to be torqued up or is that likely to damage the pins locking the diff.
- x 1943
Don't use the park position of the auto box. This will allow the shock waves to transmit through the box and may damage something there.
- x 1056
acrowot
- x 8422
The park pawl on a 4HP20 'box is a strong and massive affair but I'd be very wary about undoing crank bolts against it as I have a feeling, looking at how it works, that if there is a danger of serious overload to it, it'll jump out of engagement.wheeler wrote:Doesent sound like a good idea to do that with the park lock but im not 100% sure. Someone who knows more about autoboxes will maybe comment on this.
I certainly agree that a good rattle gun is the best way to attack this.
andycarter
acrowot
