Xantia screeching fan belt
XantiaDaveEire
x 4
Unread post by XantiaDaveEire »
hi guys :D
my car has been making this noise upon starting for the last few months but i passed it off and not having money to rectify it anyway..but now it has become worse and worse over time and the car is getting harder to start..sometimes not starting at all..as if the battery was flat..so now i have the money ..how do i go about replacing the belt or rectifying the problem
Thanks in adavance :D
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
MikeT
x 232
Unread post by MikeT »
Take a look, the belt may have shredded (like a cheese straw) and begun strangling the cam pulley et all. Could end in tears if not sorted asap.
In fact, it might already have caused unnecessary damage, making it a more expensive job so don't run the engine until it's fixed if possible.
What model is it by the way?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
What Xantia are we talking of here, your TD or HDi?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 5674
The screeching could also be the alternator bearings breaking up.
XantiaDaveEire
x 4
:shock: 1998 mk 2 td ...for about 20 seconds it does this and then its gone :oops:
x 5674
Likely not the bearings if it is only on startup.
You could try some Belt Wax like the stuff here (Pro-Belt) if the belt tension is as it should be.
DickieG
x 33
Start off with fitting a new auxiliary belt and if that fails to stop it then a worn crank pulley are more than likely the cause.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
XantiaDaveEire
x 4
will do :lol: any idea how much the belt would cost ..what about the crank pulley..i dont want to be spending much as i dnt have a lot to start out with..
DickieG
x 33
The belt is under £10 from http://www.gsfcarparts.com/ but the pulley will be the best part of £100 (new).
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
XantiaDaveEire
x 4
I had a look at the belt and it seems fine ..but il leave it in to get 2nd opinion on it..i really needed to go off now but again there was 2 ticks from the alternator and not a kick out of the car as if the battery was completly dead :evil: ..im at my wits end :evil:
fred1
Unread post by fred1 »
Hi,
Sounds like the aux belt tensioner bearing. Need to replace the tensioner.
GSF stock them.
On the manually adjustable type it is easy to replace.
Not sure about the auto tensioning type.
Regards
John
Stempy
Unread post by Stempy »
XantiaDaveEire wrote:I had a look at the belt and it seems fine ..but il leave it in to get 2nd opinion on it..i really needed to go off now but again there was 2 ticks from the alternator and not a kick out of the car as if the battery was completly dead :evil: ..im at my wits end :evil:
Are you sure it's not the starter solenoid, a clonk sound without turn over usually would indicate that to be the problem. :?
Lexia ponce
XantiaDaveEire
x 4
no i had the bonnet up ..fiddling around ..and the aletrnator makes two clicks and then the dashboard lights up but when i go to start the car the dashboard goes out or the panel goes very dim ..i may leave it in to see..as it could be any amount of problems seeminly :(
Stempy
I'd agree that it sounds like a duff battery then. Can you check the voltage? Batteries are strange things, when mine went last year it was perfectly ok one day and completely dead the next morning.
Lexia ponce
XantiaDaveEire
x 4
batterys not even a year old..the screech is still there unfortunately :(
