How do I use a Seem belt tension gauge?
dnsey
x 19
Unread post by dnsey »
Keep 'em coming Malc
I disagree -
to labour the pun would be unseemly :roll:
dnsey
x 19
be aware that not all are amused by your 'off-topic' observations
Just kidding ... keep 'em coming :D
x 8365
It seems to me that this thread has gone well off-topic :lol: :lol:
uncle buck
x 10
Unread post by uncle buck »
"Seems" like it's just another bothered meter to me....
2001 Xsara II 1.4 LX
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I seem to be gauging a degree of tension here :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Meanwhile back on Planet LHM.................
Anyone willing to profer a suggestion for the tension meter tool for my box :?:
C.
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I thought about something that could be DIY'ed but you would need benchmark specs.
Three ¾" rollerised tubes mounted square onto a steel plate, with two riding on the belt's flat side and the third between them on the cogged face. This single roller would be on a cam adjustment, like a timing belt tensioner bearing. To get the belt tension you would use your inch-pounder on the cam-mounted roller tube. When the depressed portion of the belt just touched an anvil on the flat side and clicked off the inch-pounder, you'd be close enough.
x 94
Unread post by citronut »
what meter dose one use to check your SEEM'S meter is acurate, and then i spoz you'd need another meter to check that
regards malcolm
Joe84
Re: How do I use a Seem belt tension gauge?
Unread post by Joe84 »
It is an very old topic...but i have an problem.
My car is Renault Clio 2 D7F726 (Year 2006), but not related now...
I have an MOT 1273 C. Tronic g2 105.6 Guage measure Measured Value SEEM I buyed from 2nd hand market
Based on RTA and repair manuals should be set SEEM 20+/-3 (so between of 17-23). (very low value Anyway other book write 139 +/-3 Hz)
So it should be easy to use. But I have problem...
The repair manual write you sould turn the knob till 3 clicking....
No have ckicking sound... it is an second hand part.. so missing something from it?
Becasue without clicking noise i don't know how much should be turn the knob and how much force should be press the belt. So ifyou turn less value low, turn hard, Seem value is high
If you have this 105.6 ,105.5 or same like Guage measure tool, can you check inside? Missing something from that?
