Cleaning a Xantia front and rear height corrector
All the sticky threads from the Citroen and Activa forums have been relocated here at least on a temporary basis.
red_dwarfers
x 58
Unread post by red_dwarfers »
Removal, Cleaning and Refitting of a standard Xantia Front Height Corrector
You will need:
x3 Front Height Corrector Hydraulic Union Seals (Citroen P/N - 96085 785)
Purpose made 8mm flare nut spanner (an open end spanner will round the delicate unions!)
Spanner Set
Screwdrivers of varying lengths
Pliers
White grease spray
Removing
Secure the front of the car on axle stands and block the rear wheels, best to get the front wheels a good few inches off the ground with the rams on full length for access.
Depressurise the suspension by setting the manual height control lever to low while the car is running and letting it settle.
Depressurise the accumulator sphere by turning the bolt on the sphere block on the front of the engine no more than half a turn, a hissing noise may be heard.
Be certain the car is 100% secure on the stands!
Remove the R clip which secures the manual height control lever to the manual height control rod and slip off the control lever.
Unscrew the two bolts that connects the height corrector cradle to the sub frame, this will give you a bit of flexibility when disconnecting the linkages.
Using a suitable implement, take the pressure off of the plastic anti roll bar to HC clip by manipulating the bottom plate from the NS spring
and use a screwdriver or pliers to pop off the plastic clip from the metal anti roll bar rod. Another way of doing this would be to slacken the anti roll bar metal link and pop off the plastic link but then the height would have to reset using the table in the following link (link)
Now for removing the manual height control on the OS spring. This is directly touching the spring so it is a case of pulling the height control rod towards the rear of the car and moving the front end of the spring out of its locating dip on the HCR, the other part of the spring can then be slipped out by manipulating the HCR. It may help to loosen the bolt on the HCR to ‘Socket Tool’ (according to Service Citroen) but it would be worth marking exactly where it bolted to as this can be used to vary the length of the HCR.
Loosen the three hydraulic unions then undo them one by one before blocking the ends with suitable tissue to prevent any swarf getting into the pipe or height corrector. It may help to unclip the pipes from the plastic holding channel. Make a note of which pipe goes where, on mine, the one with the largest angle is for the union towards the rear of the car.
Pull off the leak off pipe from the top NS of the HC and block with tissue as above.
Now it comes to removing the HC from the car (Bearing in mind that I’m dealing with a car with no semi or fully active suspension). After a bit of fiddling about, I found the best way to be sure that the pipes were either clipped back into the plastic channel or moved carefully out of the way, the HCR also needs to be moved to one side. The HC needs to be moved to the OS an inch or two then the front of the HC needs to continue moving to the OS just enough for the rear of the HC to move towards the NS a touch to drop down. The rest of the HC should then follow; failing that a bit of wiggling should do the trick. I hope that description was clear enough as the photos I took under the car didn’t come out very clear :oops:
Cleaning the HC
Remove the two bolts underneath the HC
Using a small pair of pliers remove the hydraulic pipe seals from the HC, afterwards renew the tissue.
Now your preferred cleaning method of the linkage, soaking overnight in a tank of diesel, painting with a small brush and diesel or other cleaner until all is clean. Check that the springs move smoothly as you may notice there are still bits of swarf in behind them. A bit of spring moving should get it out along with the small brush.
Using the white grease spray, lubricate all of the moving parts and manipulate them.
Move the HC back into the cradle and screw the bolts back in.
Refitting the HC
The HC+Cradle unit fits back in using the method of removal
Firstly, remove the tissue from the hydraulic and leak off pipes, slipping the new seals onto them so that they are all the way on the pipe. Fit the pipes back into their correct hole and loosely screw them in with the flare nut spanner. Be sure not to use too much pressure as the thread in the alloy body is easily cross threaded and the union bolt is prone to slipping off the spanner if it is not exactly the right size. This is where a small pair of mole grips come in handy (Yes, I’m talking from experience :oops: )
The rest is a reverse of removal bearing in mind these points.
When all the HC and cradle linkages and bolts are connected, tighten up the unions (though as said, not too tight)
If you did loosen the control rod to ‘socket tool’ bolt, set this back up to the correct length again, if this is slightly out, you will notice the HCL will be difficult to move to either service high or service low.
If you loosened the anti roll bar clamp, you ride height will need to be reset. For this, you will ideally need a lift, pit or wheel ramps if you’re brave enough!
Before packing all your tools away, test out the suspension.
After all the tinkering with the height control system, you should find that things click into place and you know roughly the root problem of symptoms.
Kev
'19 C4 Cactus 130 Flair
x 8369
Good work Kev :D :D
Excellent and very valuable. Thanks for posting this...
red_dwarfers
x 58
Cheers Jim :D
If anyone does clean their front height corrector and owns a decent camera with Makro focus and a decent light, clearer photos than my own would be much appriciated :wink:
Kev
MikeT
x 232
Unread post by MikeT »
Kev, your pics are good enough IMHO. Thank you for taking the time to post this.
red_dwarfers
x 58
Some extra notes for the rear Height Corrector.
A LOT easier than the front HC
Three torx bolts holding the linkage onto the car, two facing the rear, one facing the N/S.
Undo the bolts holding the actual HC on, leaving the hydraulic pipework plumbed in, taking note of the adjustment of the actual HC onto the linkage.
Unclip the plastic clip and manual height control rod.
Wiggle linkage out, one pipe is in the way but after a bit of puzzle solving the linkage can be removed without mucking about removing the hydraulic side of things. Clean HC as in the original posting.
No need to loosen the anti roll bar clamp. Its VERY unlikely to have come out of adjustment.
The rear height can be adjusted by moving the actual HC on the bolts connecting to the linkage.
Kev
Xantianut
x 124
Re: Cleaning a Xantia front and rear height corrector
Unread post by Xantianut »
Ay up!
I can't see the piccies at all!
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
Xaccers
x 188
Unread post by Xaccers »
Xantianut wrote:Ay up!
Photo bucket which hosts the images probably was having problems again.
DIY sphere tool
