Xantia engine top mount
firstrebel
Unread post by firstrebel »
I bought an engine top mount from my local Citroen parts stockist recently and decided to do it today. Having removed the 'curved retaining plate' I got a better look at the existing mount. It did not look like the one I bought - see pictures. The part number of the one I got is 1827.10, is this correct.
Haynes book then says to take out the rubber buffer, all I could see was a round handle that looked like it needed to be unscrewed, but was too tight to undo by hand.
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
dieseldoggy
Mounts
Unread post by dieseldoggy »
I think you will find theirs more than one for them? As need to have look at mine and edwards at billericay told me you need to match it up. if i remember correctly diff top brackets?
xantia 19td estate 96-7
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Looking at the photo's I take it you're changing the gearbox top mount, if so then here's an example of the old and new versions of that mounting in addition the part number you mention Bob is correct.Image
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
firstrebel
It's the one under the fuel hand primer pump.
Bob
Robert Isaac
x 94
Unread post by citronut »
Rob the lower picy in your first post is a gear box mount/hanger,
the one you need has a stud at the top and bottom of the mount/bush
regards malcolm
DickieG
x 38
The part number for the top engine mounting by the primer pump is 1827 27.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
firstrebel
Thanks. I went over to Tomo's to order it. It shows as a 'spacer', but at £9.29 (after discount) it must be something a bit more than a spacer normally is.
Bob
Robert Isaac
