Xantia Estate Tailgate bulb replacement
NAM
Unread post by NAM »
Hi All
I am trying to prise open the red tailgate braking light until to change the bulb but it is not responding to treatment. Does anyone know how to do this without breaking the unit? I assume there is a bulb in there somewhere - the manual is not very helpful.
Nigel
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
KennyW
x 165
Unread post by KennyW »
Hi Nan,
It's easy and it doesn't matter which bulb you are changing.
the brake bulb on the wing is accessed from inside the boot on both sides of the rear wing is an access panel, remove that and at the rear of the wing is the light cluster held on by a plastic type nut unscrew same and a presto the light cluster is freed.
the brake light on estate boot lid also has an access panel remove that and you have access to light cluster to replace bulb.
Good luck
kenny
C3 1.4 petrol (SWMBO)
x 8400
Hi Nigel,
It's far from obvious on an estate :wink:
On the side you wis to replace, open the side cubbyhole cover in the cargo area and then find the two black plastic wingnuts in the rear of the cubbyhole. Undo them completely and fold the rear of the cubbyhole trim down and then put your arm in and feel for the wingunts on the rear of the light lenses. Undo these wingnuts, being careful not to drop them and loose them.
The whole rear light assembly will now draw forward from outside. Clip the bulbholder assembly out of the lens and replace the bulb.
x 8400
Sorry Kenny :oops: You and I typing at the same time :roll: :lol:
KennyW
x 165
Correct Jim but just the same advice. :wink:
kenny
NAM
Thanks Kenny and Jim - I am ok with the side brake lights - it is the light unit at the top of the tailgate that is causing me grief. I have taken it out of the car - and now need to work out how to access the bulbs.
Nigel
x 8400
Ahh, sorry Nigel!
They're LEDs in an estate so they should never go and thus the unit is difficult to open... There is a series resistor (green tubular thing) that may go open-circuit but it's unlikely.
If all LEDs are out, it'll more than likely be a break in the wiring within the concertina by the RH tailgate hinge.
NAM
Thanks Jim - I will investigate. :)
