climate control help please.
dennis9112
Hi, i have a renault clio 1.5dci 2004 and i am having a problem with the climate control temperature. The panel, fan speed and lights all work ,the heater is also blowing but no matter were i put the temp it blows cold all the time , the AC seems ok and the engine temp is fine . could any one please help as to what the problem could be . Thanks
- x 5679
Welcome to the forums Dennis. Pleased to see you managed to get in at last.
I Hope we can help with the problem.
I'm guessing here until someone with specific Renault knowledge shows up but
1) Is the heater matrix warming up? can you get at the feed and return pipes and check they are both hot?
2) Could be that the diverter motor that controls the flap that opens the airflow ports is defective. On many Citroens there is a tiny gearwheel that sheds teeth and fails to operate the diverter.
If you peer into the works you may be able to see the flap moving and hear the motor - or not if it is broken, of course.
dennis9112
