I had diagnosed the throttle cable as the cause of a sticking throttle - on closer inspection it was considerably frayed, and would have necessitated a call to the AA sooner or later.
As it was a saturday I knew my local factor would get me one, which they did for £17. However, the alarm bells were ringing when I picked it up as it was also suitable for a 406, and bore little similarity to my cable.
What should have been a half hour job became a nightmare - fitting is straightforward, however the cable was well over size and came with a collection of spigots etc which did not look anything like mine.
The cable is fitted, however the pedal is "floppy" and I dont have full throttle openings - that black cylinder that clips to the airbox has a return spring ( careful - I took mine apart - the spring is under a fair bit of tension) does not come with the kit.
So a trip to the stealers is in order for a genuine item - I normally give my local factor my business, however I feel let down big time over this and while I won't get a refund I will let him know that this cable is no good for that particular application.
Does anybody know how much an OE part is? Is it a straight replacement or Do I have to get the sidecutters out again?
Throttle cable woes
Bren
Throttle cable woes
96'Xantia 1.9 td estate
93'gsxr- 750
85' Rover 3500 (work in progress)
93'gsxr- 750
- x 1055
Xaccers
- x 188
If you can, get to your local independant bicycle shop with your old cable (just the inner metal bit, carefully removed from the white plastic pedal clip).
Find a matching bicycle gear cable, the metal block on the end needs to be the same size as your old cable so it can fit in the plastic pedal clip.
Our local shop sells suitable cables for under £3.
Back at the car, fit the plastic pedal clip to the new cable, then feed the cable through the hole by your feet, out into the engine bay via the old cable's sheath.
Then through the spring loaded barrel, and through the rest of the old sheath into the throttle arm.
Tie up the excess length of cable, don't cut it as this leads to fraying.
Job done, takes 5 minutes.
Cassy's had one for a year now and still going strong.
DIY sphere tool
DIY sphere tool
- x 94
Bren
I am in Cheshire Malcolm - I understand what you are saying about the cable being too long, however it has been shortened a couple of times (on its first outing I could'nt believe how much it had stretched - I had to turn round and get my wife's car - I hardly had any throttle opening). As the spring / cylinder is missing it appears that only the lever on the pump is allowing the cable / pedal to return to its "at rest" position - not ideal surely?
93'gsxr- 750
93'gsxr- 750
- x 94
they dont usualy stretch well not by a noticable amount anyhow,
what probably happened was when fitting the outer cable possibly did not seat into the plastic ends completly, so on first time or so of pressing the throtle it pulled both ends home, to vut these inner cables i get it in the jaws of an old pair of side citters just were i needs to be cut off, hold the cutters on there side on the side face of a club hammer and hit the other side jaw with another hammer (not leanning it on the top of the head lamp ),
and yes i do have two hammers
regards malcolm
regards malcolm
