Anyone know why some Lags without Satnav have these fitted?
My car has one, and it's not been retro fitted, and has a lead to it, but no satnav, so what would it be for?
As far as I'm aware the radio aerial is incorporated into the rear screen?
Laguna II shark fin
faffer
faffer
Xaccers
- x 188
Is a GSM antenna the suitable length for GPS reception?
DIY sphere tool
DIY sphere tool
faffer
sparky33
The shark fin is used for both (sat nav and phone antenna), but there is only one cable on mine, not sure if it would have two if you had the phone kit and the Carminat.
It looks like the phone kit itself was removed at sometime, the speaker is present (left of the steering column, same one used for the woman that nags on the privilage models)and there is a yellow plug under the gear stick gaitor, this has had three wires cut from the plug and female spades attached to them?
faffer
faffer
sparky33
Found the end of the cable in the dash behind the radio, it has a screw type fit on it.
Also found this plug under the gear gaitor, any ideas? The femle spades are connected to wires cut from the plug.
The car was fitted with a Renault car kit so I'm trying to establish what is and isn't there, the speaker is the two pole and has a whilt plug attached to it.
