Hi all.
Im looking to buy a 2001 C5 HDi at the moment, the one i have found has 2 problems:
1 the speedo doesnt work, is there a common fault with the speedo's, if so what could it be (guess that it is electronic)
2 The remote locking isnt working (so im told) but it will lock with the keys and set the alarm, assuming its not the batteries in the key what are the problems with getting it going?
Rob
C5 Speedo & remote locking
h2ocooler
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
- x 1055
1) It most likely won't have a road speed sensor in the gearbox instead taking its speed reading from the ABS system, If a BSI reset by disconnecting the battery doesent work it's most likely an instrument panel fault. Is it an automatic by any chance ?
2) If its not the batteries & the remote(s) dont just need re-syncronised then its most likely a faulty remote.
