clonking noise
This is the Forum for all your Renault Technical Questions, Problems or Advice.
telderv
clonking noise
Unread post by telderv »
ive got a real bad clonking noise coming from my nearside rear suspension when going over bumps at moderate speeds, doesnt do it at high or low speed, any ideas?
LAGUNA II 1.9DCI DYNAMIQUE
swampduck
Unread post by swampduck »
sounds like the coil spring inside the shock absorber has snapped , common fault on scenics so maybe the same on yours
telderv
have had it diagnosed by both renault and kwik-fit (which was free!), its the main axle bush, is VERY common(they have a 40K mile lifespan with 17inch rims) and bloody expensive to replace, so far ive been quoted £320 and £315 to have both sides replaced, but if your handy with the spanners the parts are £40 a side
sparky33
Rear subframe bush fitting guide
Unread post by sparky33 »
Hi, here is a full guide on how to replace the bushes, you can get them for £30 the pair on ebay and the tool required can be picked up between £30 - £60 as most buy the tool to do the job then punt it on (bad move)
http://www.coupe-club.org.uk/smf/index. ... ,79.0.html
