Unidentified rear suspension component
reblack68
Unread post by reblack68 »
My old Xantia Estate has failed its MOT because of an LHM leak. It's a 2000 SX HDi with standard anti-sink suspension (i.e. a sphere on each corner plus accumulator and anti-sink).
This picture isn't the actual car but you can see the part in question. It's the gold-coloured component below the anti-sink sphere. It is leaking around the black cap at the right hand end.
http://www.flickr.com/photos/35073472@N08/3247637549/
What is the component, how much is a new one and is there a way to stop the existing one from leaking?
Richard
No French cars of my own at present.
Care of a 1994 205 D.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Its the anti-sink valve, they can't be repaired and are known to leak, IIRC about £80 new.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Pleiades
Unread post by Pleiades »
Hi Richard.
My guess is that it is the little gold coloured bit with the black rubber return pipe coming off it.
The next thing is that your car has the hydractive suspension as the unit that is leaking is the firmness regulator with the rear suspension accumulator attached, and there is another one of these at the front.
Back to the leak !!!
The leak will be the electro valve, this is an electro magnet that is attached to the firmness regulator. This electro valve has to be made from aluminium, the reason is that if made from steel then the electronic magnet inside would not work when energized. Just like on the old caliper to arms problem you have the ally to steel body corrosion problem, now what happens on this valve is that the wall of the "O" ring sealing face corrodes away untill the "O"ring pops out and you discover the "dragons blood" all over the floor.
The only solution is to get another one and the bad news is that the electro valve is about £115.00 + vat
The good news is that it c an be changed without removing the firmness regulator from the car.
In my experience this is a common problem that I get enquirys about at least once per week.
Regards
Martin.
reblack68
The car doesn't have Hydractive, that was an example picture I found on Flickr. The owner did take his own picture but he hasn't managed to upload it yet. The bit I'm referring to is below the green sphere and next to the exhaust.
Richard
Pleiades
Hi again Richard.
I could have saved myself a bit of typing by reading the first bit properly :oops:
Yes the little ally valve is the anti sink valve, again they are quite a common problem, I have sold 2 of these already this week!
The main problem is that the "O" ring grove in the end is machined wrong at the factory, so they are all on a bit of borrowed time, but failure seems to be luck of the draw, some go early and some carry on holding out for years.
Regards
Martin
reblack68
How much do you sell them for?
Richard
x 94
Unread post by citronut »
quite a while ago i fitted a new seal to a front ati sink capsule on a XANT, i found the end cap had become loos, so i fitted a new seal and tightened the cap up, and it seemed to be fine and did stop the leak,
saying all that i did it in situe so did not inspect the seal seat for any bad machinning/damage
regards malcolm
jonnydrumm1967
Unread post by jonnydrumm1967 »
So,can the cap on the end of the anti-sink valve be removed and a new seal be fitted? I presume it's on a screw thread.Citroen will no doubt not sell this O ring but I will be able to source a suitable one.
It's my car that Richard was talking about and just now I'm on a budget!
Any ideas? Thankyou.
Jon.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
x 1487
No Citroen don't sell the O-ring, but I seem to remember that there is an o-ring available that is the right size (the one for the HP pump perhaps?). Martin may well know, or be able to sell the correct ring. For MOT you MIGHT get away with backing the nut off, winding a few turns of PTFE tape around it and tightening it up again. Doubt it will last long term though!
jonnydrumm1967
Well,had a look at it today,we screwed the cap off,dug out the old O ring,put a chunkier one in,screwed the cap up and it's been fine! MOT Pass!
Thanks to all,
Jon.
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
reblack68
Nice one! Now get it on Autotrader quick!
Richard
jonnydrumm1967
It's sold already.
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
