Does anyone have the pin out info for the ABS senors also I assume the sensors plug into the ecu am I correct
Dave
C5 ABS sensors
- x 1053
Yes the sensors eventually connect to the ABS ECU.
Whats the problem ? Just so you know you can't do a resistance check on the C5 wheel speed sensors as these sensors are a type of hall effect sensor (even though the only have 2 wires) as opposed to the older style inductive sensors. you wont get any voltage from them either when you spin the wheel.
buckley
