strange fault on my x reg saxo (non central locking) ... drivers door lock will not unlock the car either with the key or using the tab thingy inside.
they both must still be connected as they will travel about half the distance required but will go no further
i have managed to get the inner door panel of but that doesnt seem to help much as i cant get my hand into anything useful and i have emptied a lot of wd40 into everything in sight to try to persuade it to release
has anyone got any ideas about what might have gone wrong (or a cunning way to get the door open that doesnt involve a tin opener)
cheers
peter
citroen saxo door lock
weety
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
AndersDK
Door locks are a nuisance when they deadlock
Hi Weety
As I read it you have already done the usual stuff to try release the lock.
Before you go for a new (breakers) door then try endless times thumping your butt gently but firmly against the door, while you apply a firm handforce pressure against door handle to unlock.
The idea is that your thumping will press in the door seal and thus apply a short relief on the lock latch mechanism.
If you hit your luck the latch will suddenly unhook while you are doing your rumba ...
x-ing fingers for you
cheers
Hi Weety
cheers
Anders (DK) - '90 BX16Image
weety
hmmm no luck yet but i am going to keep trying (got to be easier than angle grinding the door of) given it aother can of wd 40 as well
oh and i found cha cha cha a btter rhythm (if that helps)
