Hi ALL
Ive a Xantia Heater matrix to replace for a customer...
Its a T plate, 1998 HDi, and still has its original screen... I CANNOT for the life of me get the scuttle off to get at the 3/4 dash screws....
Its got the original heavy duty mastic on it.. any tips for removal.. I thought about applying heat with a heat gun or hair dryer..
Tips/Advice??
Paul
Xantia screen sctuttle trim
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
addo
- Sara Watson's Stalker
- x 95
citroenxm
- Fallen Hero
- x 70
addo
- x 95
citroenxm
- Fallen Hero
- x 70
- x 94
citroenxm
- Fallen Hero
- x 70
DickieG
- Monaco's youngest playboy
- x 33
I don't think that there is any magical solution for this one other than to use a very thin sharp knife and keep slicing at the mastic. I still managed to break the screen on my Activa despite being very gentle. On an Activa I was breaking for spares the only way I could get the trim off was by attacking it with a bolster chisel and even then the mastic pulled large sections of glass off of the screen. Good luck!
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Onlinemyglaren
- x 5671
- x 1052
- x 94
myglaren wrote:What about a chemical approach - something like turps or maybe methylated spirits* may soften it enough to allow you to cut through it with a sharp, thin bladed knife - have you tried a heavy duty snap-off blade knife?
*I'd be a bit hesitant about chucking petrol on it
especialy if your useing a hot air blow tourch TEA HE
regards malcolm
citroenxm
- Fallen Hero
- x 70
Ok guys ! Thanks magic done....
managed to get it off in one piece... I used a hair dryer! Yes really! and heated the trim slowly as its not as violent as a heat gun, and as the plastic scuttle warmed, it sofened the goooo enough for my thin knife to cut it....
The screen can take SLOW warming, but not RAPID heat change like a heat gun would apply..
Anyway, matrix in, dash in place, and screwed in place just need to put all the bits and bobs back in place in the dash..
THANKYOU for all your sugestions....
Rgds
PAul
Rgds
PAul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
handyman
citroenxm
- Fallen Hero
- x 70
Well funny you should ask!
I have about 4 bolts left!
These are from the centre of the dash, were the steel bars bolt together... I put all the centre dash back in before realising I had not put them back..
After bolting the two above the colum, and the two side ones, and the two above the drivers legs area, it was sound enough ....
So all went back fine, with nothing else forgotton.... (My 4th one Ive done now, 2x S2, 2x S1's)
Rgds
Paul
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
