c5 stiff rear suspension please help!!!
gazzas c5
rear suspension of my 52 plate c5 2.0 hdi is very stiff and hard on the road front seems ok but when you go over a bump the rear sort of bounces hard please help me or advise me what is wrong and what can i do thanks
- x 5672
Bit more info would help. Is yours a Hydractive 3+ (with the "Sport" button)? Could be sticking in sport mode. If you dredge around in the threads a bit, especially the Activa ones, there are similar problems arising and proposed solutions.
The standard trick is to perform Citroebics - fully raise then lower the suspension half a dozen times, sometimes softens the suspension and if it doesn't do any god it will do no harm, keeps all the various linkages free.
Last week I transported a stupid amount of huge sheets of MDF for a friend, along roads with speed bumps every fifty feet. After this little exercise my suspension felt markedly softer and still does. Either I have buggered it and it will collapse dramatically sometime soon, or done it some good.
Xaccers
- x 188
When were the rear sphere's changed?
DIY sphere tool
DIY sphere tool
Old-Guy
- x 24
I agree with Xac: 6 years old - classic symptoms of rear spheres blown.
Dead easy job on a Xantia, how difficult can it be on a C5?
Please make SURE the car is properly supported so it CAN'T squash you.
- x 5672
While I have to say that the diagnosis makes sense with regard to Xantia's, C5 spheres have much longer lives and it seems that no-one really knows exactly how long.Old-Guy wrote:I agree with Xac: 6 years old - classic symptoms of rear spheres blown.
I expect the only way to be sure is to have them tested. I also have an idea that you need a diagnostic computer to release the system pressure before dismantling.
There is a Citroen specialist near you that I have heard only good things about although I have no direct personal knowledge of them - Centreville Garage, who may be able to advise or inspect/test them for you.
gazzas c5
stiff rear suspension please help/advise. c5 2.0 hdi
my 52 plate c5 2.0hdi sx rear suspension is very stiff even going along the road it bounces at the rear if you go over a bump,it hasnt got the sport mode on the suspension up and down button what should i do?its really annoying as miss the smooth comfortable drive in it thanks
- x 1052
bencowell
aerodynamica
- x 215
