Car alarm chaos
shiney
Car alarm chaos
Hi
Citroen xantia 1.9TD T reg
The alarm is going off intermitently and drivng me nuts, I think it may be the wind.
Does anyone know h
if the sensitivity of the alarm can be altered?
Had to get up ttwice last night with it
Ta
Does anyone know h
Ta
Kowalski
My alarm goes off intermittently too, mine's a 97 Xantia TD. Disabling the interior sensors stops the alarm from going off.
To disable the interior sensors you press and hold (for 2 seconds) the alarm button on the dash (to the right of the steering wheel) before locking the car with the remote.
Does anybody know where the alarm ECU lives where it's earths are etc?
Dave Burns
blueboy2001
The best thing you can do with a Xantia alarm is turn it off completely using the keyswitch on the scuttle panel.
That way you get the flashing led which will put 90% of people off breaking in as they will think it's alarmed, but you don't have to get up in the middle of the night when the damn thing goes off!
David Goddard
Newer Xantia's don't have a key operated switch.
I gave up on my alarm and fixed it by disconnecting the alarm ECU. As said above, it's under the carpet (front passenger side). The seat has to be unbolted to gain access. There are two multi pin connectors - remove both. There may be a couple of single core cables. These are left disconnected. I never found out what they are for, but if you connect them, the alarm goes off, but at a much reduced volume. Perhaps it was used for commissioning reasons?
Richard Gallagher
Kered
The alarm in my Xantia started going off for no apparent reason until one day a large spider descended from behind the drivers sun visor!![:0]
I had taken some garden waste down the tip 2 weeks before and the blighter must have been amongst the clippings and escaped. I guess it was large enough for the ultrasonics to see!
Derek
Derek
Diagsys
if you get a new set of ultrasonic sensors they can be replaced in under an hour for both sides and i've found that this cures the problem 99% of the time. Just don't go to the bother of routing the cables allthe way back to the ecu, instead cut and join the cables just behind the sensors. Saves a LOT of time!
- x 1055
Kowalski
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Diagsys</i>
How much do the sensors cost and do you know what their part numbers are?
Dave Burns
Yes plugs are there so don't go hacking anything, leave that to citroen mechanics[:D]
They will set you back some £28 odd, well thats what they set me back a year or so ago, must have cured it for all of two months[:(]
One is a transmitter and the other one is reciever, they have differing plugs so they can't be installed incorrectly, unless you're a citroen mechanic in which case anything seems possible[:0]
Dave
Dave
Kowalski
Dave Burns
That was the approx. price for the pair.
The alarm (mine anyway) can still go off when the sensors are disabled so one would think their wiring doesn't come in to it, could be wrong though.
When you have gone out to it a few times in the early hours you get a bit cheesed off, then the easey option is to simply leave it off rather than go buggering about taking the seat out and what have you.
Dave
Dave
Kowalski
My current Xantia is relatively new and shiny at the minute and I'm trying to get all of it's little faults sorted out so that it's "perfect".
I do agree that not setting the alarm is a possible solution to the car alarm problem, but I still want the deadlocks set and I can't set them remotely without setting the alarm as well, hence disabling the sensors.
My alarm doesn't go off if the interior sensors are disabled so that is why I think they are responsible for the problems.
davek-uk
It's just a thought (and you can shoot me down in flames as I haven't a clue what I'm talking about) but the handbook says the alarm senses the cabin pressure. This could be changed I'd imagine by wind blowing around the heater air intake - if the system was too sensitive it may be enough to set it off. Would it be worth trying the alarm with the heater fresh air/recycle switch set to recycle?
