Is there a common engine mounting fault on the 2.0 hdi xantia
I get a grumbling noise at low revs on my V 2000 xantia and a knock on clutch take up
A quick look and I suspect the lower G/Box mount but wondered if there was a common culprit
xantia engine mounting
DickieG
- Monaco's youngest playboy
- x 33
Is your Xantia HDi a 110 bhp model if so trust me here, but the noise may well be emanating from the brake calipers as they tend to rattle around in the calipers at low revs. To work out if it is the calipers, the next time you hear the noise gently pull on the handbrake until you feel a resistance if the noise stops you need additional bracing springs fitted as part of a Citroën service bulletin.
Also take a look at the following post http://www.frenchcarforum.co.uk/forum/v ... highlight=
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
