I have aquired a new pair of lower rear wishbone bushes for my '93 AX debut (bushes with 2 mounting bolts with metal tube insert) When removing the old bush from the vehicle, as there was a large amount of play, I noticed that the bush had no inner metal tube and was just a rubber hole where the wishbone went in. Am I correct in thinking that the metal insert from the old bush is stuck on the wishbone? The diameter of the tube on the wishbone is the same of that of the new bush. Wish a had a digital camera so I could show you. Basically I think I want to hank the inner part of the old bush off of the wishbone, so to replace with new bush, but I can see no seam! it looks like a whole unit! Has anyone got any advice, or a diagram you can show me. I have no haynes book for this model.
Thanks, Tris
AX, Replacement bushes.
Jon
tris
AndersDK
This diagram :
http://citroeny.cz/servis/axser/predni_stabilizator.gif
More on :
http://citroeny.cz/servis/servis.htm -> AX
More on :
tris
- x 1061
