C5 beam converters
civvie
x 21
C5 beam converters
Unread post by civvie »
Going over the jolly ole France for the weekend and managed to get a photocopy template from local dealer to stick something over the headlights.
My what a palaravor? there is nowhere I can get a reference as to where they should actually stick on the glass, does any one know if a cover can be purchased that makes the job easier, even those ones you get from Halfords are just as bad.
Even dearer and one use wonders.
Steve
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Surely the C5 masks can be more complicated than the Xantia. I need to convert my beams fairly frequently so I cut them out from a roll of black fablon, having copied the template from the Lucas kit (in Halfords)
x 1050
Unread post by wheeler »
the C5 acessory headlamp protectors have markings on them to show you where to put the stickers on.
NiSk
Unread post by NiSk »
Almost (I said almost . . . ) makes you yearn back to the old Renault 5 with a little lever under the headlight to convert it from R.H. dip to L.H. dip . . . (I did say almost) . .
//NiSk
blueboy2001
Unread post by blueboy2001 »
I was a naughty boy when I went to France earlier in the year and didn't mask the headlights. Nobody flashed me or seemed bothered by it.
allmond
Unread post by allmond »
Well, they don't bother when they come over here........
civvie
x 21
Thanks wheeler just what I was looking for, yes I use a roll of fablon as well. It was easy on my old xantia.
Doing this clears my consience about sticking it on high beam when I'm flashed in France, I don't think these bits of plastic are 100%
Thanks Again
Steve
rabenson
Unread post by rabenson »
I find that a roll of wide black electricians tape can be used to make hundreds of beam deflectors - sticks on fine and comes off when you want it to!
Nikolaymk
Unread post by Nikolaymk »
Does anyone have the template to be used on the Xantia headlamps (pre facelift)?
Cheers
JohnD
(Donor 2022)
x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Nikolaymk</i>
Cheers
The template is the same for all Xantias from '93 onwards. I'll try and describe them, looking towards the headlamps. The top right sections are covered by a mask 100mmx55mm. The bottom left sections are covered by a piece 80mmx40mm. Both areas are joined by narrow strips. All the perpendicular cuts are angled to correspond with the edges of the lamps. Having driven overnight with unshaded dipped-beams, and suffered the anger of French and Spanish lorry drivers, when the masks are in place, I know that they do work effectively.
Nikolaymk
I'll try that. Many thanks John
