Anyone any idea what could cause what the person here is describing??
http://cgi.ebay.co.uk/1998-CITROEN-XANT ... 286.c0.m14
I was thinking of removing the spring bit of the peddle and putting something hard in there as well as flushing out the LHM as well and maybe the pads too??
maybe a project for someone??
Braking issues on a 2.1
Xaccers
- x 188
OMG!
So tempted to bid on that, would be ideal to test a 1.9TD IP swap on!
DIY sphere tool
DIY sphere tool
KP
- x 27
Xaccers
- x 188
You're evil KP, but I like you
Bid placed.
Not likely to win it though.
Bid placed.
DIY sphere tool
DIY sphere tool
KP
- x 27
Xaccers
- x 188
It's likely to go way higher than what I've put as my maximum (unless no one else notices it)
DIY sphere tool
DIY sphere tool
- x 94
OnlineCitroJim
- x 8386
- x 5671
The link crashes Opera so I haven't a clue what it might be but regarding bidding - DON'T.
Instead, snipe it with Auctionstealer UK.
I never bid on anything, just decide the upper limit I'm prepared to pay for an item then snipe it. Your bid goes in approximately 10 seconds before the end of the auction - you can still be outbid of course but that's how auctions go. It does help to limit uneccessary ramping of the price (which is what the seller wants, of course)
You get 3 free snipes per week.
TBONE
deian
restricted free movement? thats a bit of an oxymoron isn't it.
Sounds like the little bubble/switch under the pedal has burst, there is no mention of leaking though.
Or the calipers have ceased. i.e restricted free movement of the calipers, and the guy botched it up cos he didn't know they "wind" back rather than push hydrauliclly like some cars, maybe the calipers are now off line.
How hard can it be to fix the brakes, whether it's a mechanical or hydraulic problem? Not too taxing for us citroen guys i'm sure.
OnlineCitroJim
- x 8386
A doddle reallydeian wrote:How hard can it be to fix the brakes, whether it's a mechanical or hydraulic problem? Not too taxing for us citroen guys i'm sure.
I can't help thinking it's rather strange for a car to be put up on the 'bay so cheaply just because of a braking problem. It smells a bit to me. Surely it would not have cost that much to have had it sorted for the MOT?
Still, if genuinely that is all it is, someone might have a bargain...
Xac, there are a number of considerations to fitting a mechanical pump. The engine ECU does much more in a 2.1 than just run the pump. It runs the whole dash for one thing. I'm not at all sure how the ECU will behave with no pump on the end of it. Plus you have to rig up a new throttle cable. I know a 1.9TD ECU is happy without a pump except for the light but a 2.1TD is an unknown quantity in this respect.
Interestingly, I have a 2.1TD pump cradle sitting on my bench. That'll allow an initial test to ensure a Bosch VP20 in fact fits the EPIC cradle.
An interesting project though but I'd rather it was on one with a dead pump...
KP
- x 27
