Haha! Made you look! Ok, pre-empting myself a bit here but it needs fixing if
I intend using my black A6 TVA during the dark and miserable days ahead,
so watch this space!!
Andrew
Problems & Fixes - heater matrix TBC!
andmcit
- x 30
- x 8441
Wow! so we have A6TVA and A16TVA in the forum. Brilliantsuperloopy1 wrote: My 'Dante Red'Activa - A16 TVA - will get a wash and then piccies posted, hopefully this weekend.
Andrew, you know a new heater matrix will make all the difference. You'll be able to just leave the temperature slider on 22 degrees for the rest of the season now and not worry about a thing, just enjoy warm air, clear windows and that oh, so satisfying faintly oily smell that a new matrix gives to remind you of a job well done. Life, the universe and everything will seem better for getting that job done and out of the way
andmcit
- x 30
The one single aspect that REALLY worries me, doing a very good job of
putting me off, isn't the dash strip down or the heater box unmounting
- that's just a methodical spanner job.
No, it's the removal of the scuttle trim without ruining the screen and
successful refitment to prevent a swamp in the front footwell - been here
before and still smart thinking about how easy it was to comprehensively
crack and ruin the screen from such a minor application of pressure on
the trim...
Don't fancy a rerun!
Andrew
the trim...
Andrew
DickieG
- Monaco's youngest playboy
- x 33
Been there done that on what is now Jim's Activaandmcit wrote:No, it's the removal of the scuttle trim without ruining the screen and successful refitment to prevent a swamp in the front footwell - been here before and still smart thinking about how easy it was to comprehensively crack and ruin the screen from such a minor application of pressure on the trim...![]()
Andrew
On another Activa I broke for spares the scuttle trim was so well glued down I had to use a bolster chisel on the trim to get to the wiper motor so you can imagine the state of the screen afterwards!!
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Exhume.dk
- x 3
Hello Gentlemen
Brand new to this excellent site, and owner of a Activa as well.
Needles to say, but it also had the "Matrix-issue" and i gues the main reason it was put up for sale in the 1 place.
I just jumped right in, took 2 days of from work and dug in(with my Haynes until it realized it's complete lack of info) but was to say the least, still overwhelmed by the..hmm..sheer complexity of this task.
However, since the testdrive prior to the purchase, i just couldn't leave this car alone or unattended anymore since the seller talked about selling it for parts.
Took some Pic's of the job, but not with a rocket-science degree, but mostly to fit the right part of the harness prior to dashbord reinstall.
scuttle trim without ruining the screen came across that frase...and must ask what does it mean other than its a danger point of some sort, but have not come across that issue, among so many other issues, or maybee i have, but dont understand the "situation", maybe i have overlooked it
Can anyone clarify
Have a good Sunday
Christian (Denmark)
Can anyone clarify
Have a good Sunday
Christian (Denmark)
andmcit
- x 30
In bitter past experience I have discovered the plastic trim that spans
the width of the car at the base of the front windscreen beneath the front
windscreen wiper arms is applied with glue/mastic that is far stronger
than the outer laminate layer of glass. Even with laborious careful paranoia
I still had a crack and an edge chip of glass break off the last one I
attempted to remove.
Unfortunately, this is required to allow access to the the dashboard
mounting through bolts in the bulkhead engine bay firewall.
As a warning I would tell anyone contemplating working in this area to
be extra vigilant with the removal of this trim as unexpected damage/cost
will be very unwelcome.
Andrew
Andrew
andmcit
- x 30
Christian, please share with us any pictures/stories of your very fabulous
sounding manual gearbox V6 ACTIVA in the 'Readers Rides' thread in this
Activa area!
In the UK, Citroen only saw fit to sell the V6 as a 24v v6 automatic and
the Activa as a 2.0i TCT. I don't speak for the other contributors here, but
am pretty sure your car is my ideal 'ultimate wish' Xantia Activa. Pictures
of such a wonderful car would be very nice!!
Andrew
Activa area!
Andrew
Exhume.dk
- x 3
Cheersandmcit wrote:In bitter past experience I have discovered the plastic trim that spans
I see where this is going
Still havent re-glued it back to original position, since the "losse trim" could prove handy, in remowing leafs and other debris, form the inlet of the fan, and also to clear the 2 rain outlets in each side.
Obviously if it makes any wind noise or looks ..tacky, i will re-glue it. So i'll have to make yet another fieldtrip in the car..what a drag
*looking in the photo file* Yes, I'll attend to the matter right away.andmcit wrote:please share with us any pictures/stories of your very fabulous
Activa area! .
andmcit wrote:In the UK, Citroen only saw fit to sell the V6 as a 24v v6 automatic and
- x 8441
A very warm welcome to the forum Christian
It is very important to reglue the trim otherwise rainwater will run straight into the heater intake and run under the carpet. You will not know until you lift the carpet and find about 20 litres of water soaked into the foam under the carpet
You only need to glue the part immediately above the heater intake and about 15cm each side.
Silicone RTV is fine for the job
We're all very eager to hear more of your V6 Activa! very nice
Exhume.dk
- x 3
Cheerscitrojim wrote:A very warm welcome to the forum Christian![]()
It is very important to reglue the trim otherwise rainwater will run straight into the heater intake and run under the carpet. You will not know until you lift the carpet and find about 20 litres of water soaked into the foam under the carpet![]()
Silicone RTV is fine for the job![]()
*Runs franticly out the door with black ducttape to close the gap* , since its been raining all day, and will continue to to so the next few days
Have completely overlooked that senario
Gonna jump on this tomorrow after hours
RTV..that engine silicone sealant, right ?..will it stick enough?.. had a plane of doing it with the windscreen sealant/adhesive, i have both on the job. Although the RTV is that lame orange color
Thanks for the warm welcome, Gents
- x 8441
Similar but not orange. That'll stand out, even on a Dante' Red Activa!!!Exhume.dk wrote: RTV..that engine silicone sealant, right ?..will it stick enough?.. had a plane of doing it with the windscreen sealant/adhesive, i have both on the job. Although the RTV is that lame orange color
RTV means "Room Temperature Vulcanising" meaning it goes rubbery at room temperature.
I've used automotive quality silicone sealant that looks and smells very much like you use on your bathtub to seal it to the tiles. My local windscreen fittter has it in black but the clear (translucent) variety is just as good and easier to obtain.
It sticks well if you give the glass and trim a good clean-up with a fairly powerful solvent first. Something like carb cleaner.
I always check the seal as I've now stripped the interiors out of two Xantias in order to dry them out
Exhume.dk
- x 3
@Citrojim..priceless
I find a set of Xantia carpets spending a week drying out hanging over the stair rails in the house is not good for domestic harmony!! LOL
Room Temperature Vulcanising it is
..i think that all the sudden we are fresh out of orange RTV, and i´ll resupply in the propper black
Cheers
Cheers
Exhume.dk
- x 3
Noooo...checked the carpet, wich i knew was dry, completly dry before the matrix-operation, but not anymore
Thanks for the heads up, Citrojim
Noticed that the rain will fall into the funel via the angeled spacer with the mesh on..
Oh-well, hoping the Aircon will draw the humidity out, its not soaked or anything like that, but hardly dry anymore.
Lesson learned
Lesson learned
