Helped a friend change a clutch on the picasso this week, after waiting on parts etc.. (new clutch fork & guide) it ran into 2 days. Now after rebuilding the car wont start.
The engine will crank over but thats all. Has it losted the key code being disconnect from the battery for so long?
Can this be resync'd using the key/ buttons or is it a trip to the local auto spark.
Also the black box beside the brown one near the ecu in the engine bay, shorted out to ground - but it wasnt starting even before this happen
Any ideas - all earth straps are in place...anyway of testing to make sure the crank sensor isnt at fault?
Thanks in advance
Martin
Picasso 2.0HDI 2000 non start after clutch change
msmbus2000
- x 1056
Do you mean you have shorted the ECU against the battery psitive jump post next to it ? did you disconect the battery under the seat before you tried to remove the jump post ? if you have shorted it against the positive you may have blown the ECU. try putting a temporary earth wire between the ECU casing & a good clean earth poin on the body it may jus work if it has been shorted.
If you suspect the crank sensor & it may have been damaged doing the job, remove it & check the sensor/plug/wiring for damage, if it was working fine before it doubt very much it has just went faulty. Have you checked the resistance of the sensor ?
msmbus2000
- x 1056
I think the back box your talking about is the glowplug relay. Is the car cranking ? do you have dash lights ? If your geting nothing then you may have blown the main fuse at the battery positive terminal, the fuse aint available seperatley & comes as part of the lead & is a very nice job to replace.
msmbus2000
- x 94
msmbus2000
