I just posted the measurements of mine in the Blog and wondered if I should re-shim them?
The exhausts are ok but the inlets are all over the place with two of them at opposite ends of the tolerance limit. My first thought was I mixed up the parts but I was very careful to seperate and identify them so I can't really understand what's wrong. Any ideas?
Valve clearances
MikeT
- x 232
Valve clearances
jgra1
- (Donor 2021)
- x 36
hi Mike, did you do any valve work ?
Worth gettting then close if you can.. I have 8 shims lying about and Jim probably has another 100
but you'll need to take camshaft off and work out what you have and what you need.. micrometer and some simple spreadsheet calculations... etc.
John
edit
sorry Mike just read the blog
You did a fine paste lap of the valves..
anyway, i have some shims if it helps..
John
edit
- x 8173
Yep, that'll be about right Johnjgra1 wrote:hi Mike, did you do any valve work ?
I have 8 shims lying about and Jim probably has another 100![]()
Mike, I have an Excel spreadsheet to take the hadache out of calculating the shims you need. It's up on my website but hidden. I'll advise the like when I'm home and can look at the server to see where it is..
You'll need a micrometer to measure them properly. You can get an adequate micrometer for less money than an adequate vernier caliper. You need to measure to two decimal places ideally. Also, measure clearances very accurately with a set of feelers that go down to .01mm otherwise your shim calculations will be wrong.
If you have a good imperial micrometer, that'll do, just convert the measurements into mm.
MikeT
- x 232
You're right Jim, I need a new set of feelers and my micrometer is imperial
I can't resume work until Sunday evening now but I'll pick up a new set of feelers while I'm out this weekend.
Shim sizes according to imperial micrometer.
1. 121-122 thou (3.07 - 3.1mm)
4. 120 (3.05)
5. 121 (3.07)
8. 118 (3.0)
Using mental guesstimations, I'm thinking of swapping 1 to 8, 4 to 5, 5 to 1 and 8 to 4.
Thanks for the offer of shims lads, hopefully I won't need them. By the way, I notice the shims are "wear marked" by the valve stem - would it make any difference flipping them over so the mark is mating the follower?
4. 120 (3.05)
5. 121 (3.07)
8. 118 (3.0)
- x 8173
That can often work wonders Mike!You may even find you can swap shims arround and find you don't need any replacements.MikeT wrote: Using mental guesstimations, I'm thinking of swapping 1 to 8, 4 to 5, 5 to 1 and 8 to 4.
No, no worry at all about flipping them over. The wear will be so slight as to be inconsequential...
I've still not dug out the spreadsheet. I was a bit busy (non car) last night...
- x 94
MikeT
- x 232
- x 8173
- x 94
MikeT
- x 232
I've tried various combinations of shims and followers and I've settled on the following measurements. It's not possible to get all lobes facing perfectly upright anyway so accurate measurement isn't wholly possible. I would prefer all the gaps to be under rather than over but what do you think, bearing in mind the BoL states the acceptable tolerance is +-0.08mm?
1. 0.18mm (+0.03)
2. 0.34mm (+0.04)
3. 0.33mm (+0.03)
4. 0.14mm (-0.01)
5. 0.14mm (-0.01)
6. 0.34mm (+0.04)
7. 0.34mm (+0.04)
8. 0.14mm (-0.01)
1. 0.18mm (+0.03)
2. 0.34mm (+0.04)
3. 0.33mm (+0.03)
4. 0.14mm (-0.01)
5. 0.14mm (-0.01)
6. 0.34mm (+0.04)
7. 0.34mm (+0.04)
8. 0.14mm (-0.01)
- x 94
how tight are you doing the cam cap nuts up each time you fit the cam, in between mesuring the clearance's
as this will give you differnt readings each time
also it should be easy to get the cam lobes pointting upwards to mesure the gaps,
they do not need to be pointting upwardsto the exact micron
regards malcolm
regards malcolm
- x 8173
MikeT
- x 232
I torqued the nuts to 20 newtons as per BoL, Malcolm. All I know is that if I stop the lobe before or after (TDC shall we say
) I will snag the feeler that previously slid in snugly. I'm assuming the difference is 0.01mm or less but it's perfectly repeatable. After taking several sets of measurements (without removing/refitting the caps) I'm satisfied they're well within tolerances.
Next job turbo and manifold...
MikeT
- x 232
If anyone else is looking for a decent set of feelers I can highly recommend http://www.virtualvillage.ie/ (search for "feeler") for the princely sum of £3 inc p&p from China. Much cheaper than rip-off Britain's £10-£15+£4 p&p I found.
They even come in their own plastic case and a 25% off next purchase coupon.
