This person seems to think so (scroll down a bit)
http://forums.moneysavingexpert.com/sho ... st12595647
Could you get 1000 miles to a tank in a Xantia?
XantiaMan
- x 18
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
rory_perrett
When the fuel blockade was on in Sept 2000 as the week went on I got more and more careful and managed 64mpg out of my BX which normally gave me 50mpg. That's a 28% improvement. My current Xantia HDi is giving me 55mpg with normal behaviour, a 28% improvement on that would be 70.4mpg with the Xantia's 65 litre tank that would give you 1006 miles on a tank. Total conjecture but not beyond the possible given the right conditions (and incentive).
Xaccers
- x 186
As an experiment, driving at 55 everywhere I could, coasting down hills, turning the engine off if going to be sat for longer than a minute, and slip streaming, I managed 816 from my '95 hatchback, and that was on cheap kumho tyres.
Don't see why you shouldn't be able to get 1000 miles.
Would be very boring though.
Currently I get 3-400 from a tank
Must remove that lead block from my right shoe somewhen
DIY sphere tool
DIY sphere tool
Toby_HDi
- x 3
I thought that coasting isn't best way? Leaving in gear and applying no throttle means the injectors are off and so you don't use any fuel. Or have I got it completely wrong with diesels?Xac wrote:As an experiment, driving at 55 everywhere I could, coasting down hills, turning the engine off if going to be sat for longer than a minute, and slip streaming, I managed 816 from my '95 hatchback, and that was on cheap kumho tyres.
Currently I get 3-400 from a tank![]()
It would be nice for my HDi to get 1000, and I reckon it could. As you say though, very boring
3-400!! from a 1.9TD
- x 1240
I would think that a 2.1td could, they are better than the 1.9. I dont know what the capacity of the Xantia tank is but my XM with a 17 1/2 gallon tank regularly exceeds 800 miles without trying to hard. On the journey we do once or twice a year to the north of Scotland, between Tesco's in Axminster and Tesco's in Inverness usually gives me around 55 mpg, I make that 877 miles to completely empty the tank, but that's mainly motorway miles, it doesn't do quite as well in the mountains!
But that's not really trying, I try to drive economically, light throttle, keeping the revs down, no unnecessary braking etc but still doing 60 - 70 mph, I reckon with a bit of restraint 1000 miles would be feasable.
Anyone like to sponser me?
addo
- Sara Watson's Stalker
- x 95
The tank capacity is actually more than 65 litres, so you should find the "magic thou" a snack with such excellent economy.
One guy here reported running until it started coughing (just as he pulled into the service station, too!) - he then got a hair over 70 litres into the tank. Our pumps are pretty accurate with volume; it's the staff and their shortchanging skills one has to watch.
FWIW my fuel consumption is 12.2 pence/mile, converted - petrol engine, though.
Cheers, Adam.
p.s. The Australian tank is no different to the UK one in P/N.
Cheers, Adam.
Xaccers
- x 186
It's all mechanical, so the pump sprocket turns, the pump pumps, and the injectors squirt.Toby_HDi wrote:I thought that coasting isn't best way? Leaving in gear and applying no throttle means the injectors are off and so you don't use any fuel. Or have I got it completely wrong with diesels?Xac wrote:As an experiment, driving at 55 everywhere I could, coasting down hills, turning the engine off if going to be sat for longer than a minute, and slip streaming, I managed 816 from my '95 hatchback, and that was on cheap kumho tyres.
It would be nice for my HDi to get 1000, and I reckon it could. As you say though, very boringand you couldn't carry much weight either.
3-400!! from a 1.9TDthat's actually insane. You really must have lead boots
If you could disengage the sprocket or control the flow to the injectors (such as with an electronic pump) then yes it'd use no fuel, but in gear or in neutral, if your foot is off the throttle it's using the same amount (ie tick over amount).
DIY sphere tool
DIY sphere tool
KP
- x 27
- x 1240
KP
- x 27
Xaccers
- x 186
Then you will have engine braking which will slow you down quicker so you'll not travel as far, have to start the engine again and use fuel to gain speed to then engine brake and repeat.KP wrote:Unless you leave it in gear and turn the engine off, ie to the accessories position? that way the HP pump is still being turned over and the fuel pump cant draw any fuel
DIY sphere tool
DIY sphere tool
KP
- x 27
Ah yes but for example( as happens a lot in my travels to a from work) if you are approaching a rail crossing and you are doing the national speed limit(
)and see the barriers go down or know you will be waiting a while, you can slip the igntion to MAR and then coast down safely to near stopping speed while still in gear and just dip the clutch at the last second as you would do normally and use the footbrake. this saves some fuel and some brake pad material
- x 1240
KP
- x 27
- x 1240
