A work colleague is looking to change his cam belts etc on his 95 Xantia TD, and I was going through the list of things he'd need.
I mentioned coolant and he said he'd put in about 500ml of orange organic.
Doesn't this gloop up when mixed with the normal blue?
If so, any suggestions on how to clean out the coolant system fully?
Organic anti-freeze added to coolant
Xaccers
- x 185
DIY sphere tool
DIY sphere tool
lexi
- x 134
Always understood not to mix different types of anti- freeze as it can rot radiator etc. Ethylene Glycol and Mono Propylene are two example of this.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Xaccers
- x 185
That's what I understood too.
Any ideas on how best to clear out the mix?
He'll be changing the cambelt and water pump in a couple of weeks, so will be draining then, but will that be enough or should the system be flushed?
DIY sphere tool
DIY sphere tool
jmd
I agree with Lexi. Looks like he purchased, or asked for coolant for a Citroen & whoever sold the product assumed it was for a C5, which is LDS & mixing it with Ethylene Glycol is not advisable. I would use a radiator flush, follow the directions on the container then get the garden hose, and flush backwards & forwards, Then purchase Ethylene Glycol & distilled water mix 50% 50% and refill.
Xaccers
- x 185
Cheers, will let him know.
DIY sphere tool
DIY sphere tool
Onlinemyglaren
- x 5613
