Also, are the pin sets available from anywhere other than Citroen as they're £20 odd a side and this is getting to be an expensive hobby?
Brake caliper pins
Stempy
Brake caliper pins
It's never that simple is it? Went to replace the discs and pads this afternoon and the pins are seized solid.
Anyone experienced who could pass on a little advice, Haynes says 'simply drive out the pins with a punch'! Grrrr
Lexia ponce
Lexia ponce
Xaccers
- x 185
I normally use an old small philips screwdriver and a lump hammer to "gently" drift the pins out.
Make sure you've removed the securing clips though as they tend to snap leaving a bit through the pin's hole preventing their removal.
If that happens, drift them out if the pin hole with an even smaller screwdriver.
Spraying with half a can of WD40 etc also helps.
I greased mine before refitting them last time.
If your securing clips have snapped, try a paperclip (one of mine was actually kept in place by a bent staple!)
DIY sphere tool
DIY sphere tool
- x 94
try your local factors for a pad fitting kit, this should include every thing for both sides, if its the AX you are talking, the other thing they suffer with is the smaller calliper slide binnding, as its a rubber sleave with a nylon insert, and what happens is the alloy of the calliper grows and crushes the sleave, wich stopes the calliper slidding as it should , then you end up with over heated and warpped discs
regards malcolm
regards malcolm
Stempy
Yes it's the AX alright. It's strange but there are no retaining clips on the pins, they just seem to be pushed in, trouble is I can't push them out again. May have to remove the caliper if all else fails.
Lexia ponce
Lexia ponce
- x 8172
Ahh, so it's the AX Stempy. I know those pins so well and I've fought battles with them in the past when I had an AX. Shocking design
The only answer is as Xac says, drift 'em out but use Plus Gas rather than WD to start the process along. It is far more effective, albeit far more expensive.
I used a proper pin punch that was just a tad smaller than the diamater of the pins and whacked them out with a biggish hammer (might even have been a club hammer!)
I don't think taking the calipers off will help, best to do them in-situ and it also avoids more potential aggro with the bleed nipples. Chances are they're well seized and will shear at the sight of a spanner
It's aggro you don't want just yet but if they do shear, it's not too bad a job to drill them out and carefuly tap the caliper to take the next nipple size up.
Once the pins start to move, the game is won. Do, as Malcolm says and get a new fitting kit as the old pins will be a bit the worse for wear when they do let go. You may find that oce they start it'll help to rotate them using a good pair of those pliers that some call water pump pliers.
Stempy
Ok thanks all, I shall avail myself of a pin punch then prepare for some BF&I. I've already given them a good soaking in penetrating fluid (strange stuff, smells of mothballs). Oh the joys of Citroen ownership. ](./images/smilies/eusa_wall.gif)
Lexia ponce
Lexia ponce
- x 94
Stempy
Ahh, so there's a spring collar, I wondered what kept them in place, other than crud and corrosion. Unfortunately I don't own a diesel vehicle from which to nick some fuel.
Lexia ponce
Lexia ponce
handyman
Stempy, you can also use automatic transmission fluid as a penetrating fluid. I would also suggest if the pins are really stuck with crud, clean around them with some heat and a wire brush, then apply the penetrating fluid, but not near a naked flame, otherwise we'll have "Burnt AX Stempy".
Handyman
Handyman
Stempy
Mmmm, the blowtorch method did cross my mind but I'll try without first, I've given them a good clean up and soaked them in fluid, I'll give them another squirt tonight and get hold of some new pins and a pin punch, then I can spend a nice bank holiday weekend smacking the hell out of them 8)
Lexia ponce
Lexia ponce
Kowalski
If you're thinking about using heat bear in mind that the numerous rubber bits (e.g. flexible hoses) will not like the hot exhaust from your torch and the fact that everything is coated with oil may be a problem too.Stempy wrote:Mmmm, the blowtorch method did cross my mind but I'll try without first, I've given them a good clean up and soaked them in fluid, I'll give them another squirt tonight and get hold of some new pins and a pin punch, then I can spend a nice bank holiday weekend smacking the hell out of them 8)
My tip would be to use the largest most solid drift (round bar, pin punch etc) that you can get onto the pin. Make sure that the end of the drift is flat and that you get it square on the pin when you hit it with the hammer otherwise it'll not transfer the impact to the pin. Once the big drift gets it to move, you can knock it through the hole with one more suited to the size of the hole.
Xac's suggestion of an old philips screwdriver would work if its the "knock through" type with a metal end on the handle and you're prepared to grind the philips end off i.e. turning it into a pin punch with a nice handle.
Stempy
Cheers all, the battle is now won and the AX is now a good 'un. Well, as good as an AX gets.
Lexia ponce
Lexia ponce
