Mk2 or Series 2 or Xantia 2 - which is true?
André Citroën
Unread post by André Citroën »
citrojim wrote: Anyone know the RP number of the changeover?
5973 was the first Xantia in 17th march 1993
6370 the chevrons moved from the bonnet to the grill in 18th april 1994
7688 was the first Xantia II in 26th november 1997
8882 was the last Xantia in 4th march 2001
x 8210
Thanks Andre :D So my old TD at 6086 is pretty early then...
MikeT
x 232
Unread post by MikeT »
I'm better informed on the head gasket notch system now and the old gasket that came off (a 3-notch) is not the thickest as first thought. It's actually midway on a scale of 1-5 as opposed to the old 1-3 system. :?
Seeing as I've bought what is the thickest possible, the engine's going to suffer low compression problems, isn't it?
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
just done same Mr Mike
the word is, we shouldn't notice it :twisted:
may try update blog later...
j
x 8210
MikeT wrote: Seeing as I've bought what is the thickest possible, the engine's going to suffer low compression problems, isn't it?
Maybe the CR will be down a touch but nothing to worry about Mike. The difference, in real terms, will be very small and a slighly lower CR may aid long-term reliability a tad :D
I think that was the gasket we used on Xac's car and that still flies!
MikeT
x 232
As long as it doesn't give starting problems, the upside being I can up the turbo boost even more :lol:
It does make me wonder when you consider the reason for doubling choice of thicknesses was to ensure a more precise CR is attained!
x 8210
MikeT wrote:As long as it doesn't give starting problems
As long as you have good glowplugs, you'll start OK Mike :wink:
I think they made a choice at build time as they have to be certain that the engine will perform correctly at the extremes of its range of use.
Using a thick gasket and dropping the CR might just cause you problems starting in the winter if you decide to move to Siberia Mike but if you continue to reside in Christchurch, I don't think you'll have problems and as you say, you can up the boost!
