hi guys,
does any one know how to get the heater switch out of the center console on a 106 t reg? alternitivly, how do i get the console off or lose so i can get behind it to the rear of the switch?
my daughters car only blows on max and i want to check the switch. also are there any other bits i should look at if it's not the switch.
thanks for any help you may have, it's her baby and it's getting her down.
106 heater switch
AndersDK
markja55
AndersDK
I believe you should first try the blower motor.
According to servicebox there is no separate speed contol module for the 106 blower fan with no aircondition fitted.
This means that the speed module must reside on the blower motor body itself - somewhere up under (in UK) drivers side of dash.
There is of course a chance the control switch is failing - or a connector has dislodged in the center dash. But mostly speed related problems are to be found in ny speed module itself.
Anders (DK) - '90 BX16Image
markja55
markja55
- x 1043
