Saxo 1.4 petrol cutting out when hot
Paul S
Unread post by Paul S »
My 1997 Saxo 175k miles has started to cut out on the move on hot days when in traffic. Some times it is just a hesitation and some times it lasts 5 or 6 seconds. The fan seems to be coming on OK and the coolant is not overheating. The engine light doesn't come on when it does this.
It seems like something under the bonnet has become temperature sensitive. Anyone have an idea where to start?
x 94
Unread post by citronut »
maybe the coil pack as these are prone to packing up, if it is GSF do sell them, what modle/engine size SAXO is it
regards malcolm
Paul S
It is a 1996 model year 1.4i VSX 3dr
x 94
aahh now i think im right in saying the coil pack for a VSX is a lot more dosh than the standerd SAXO one, also its a diferant plug on the loom
regards malcolm
ps.
i have just looked in an out of date GSF catalouge
SAXO 1.6/ 16V/VTS part No. N92518 125.00 squide
x 1045
Unread post by wheeler »
Its not a 16v VTS though, being a 96 model i would guess its the old style coil pack with plug leads.
x 94
i thought the VTS is 16V as the VTR is 1.6 8V
regards malcolm
x 1045
citronut wrote:i thought the VTS is 16V as the VTR is 1.6 8V
regards malcolm
Your right, the car in question though is a 1.4 VSX not a VTS or a VTR.
The 16v coils are completely different to the 8v versions.
x 94
good point wheeler
my short term memery came into play there for a min (or was that half an hour) so i either forgot or did not read corectly the car in question is a 1.4 VSX
regards malcolm
Paul S
Changed the coil pack (£31 from Eurocarparts compared to £60 from GSF) but am still getting the same problem
newmezuk04
Unread post by newmezuk04 »
Air Leak???
My 91' 1.4i ZX did the exact same thing, but it was still bad even if cold.
The hesitation/jerking was ridiculous and it just kept cutting out, would fire straight back up again if it did cut out mid driving (such as slowing to a junction), that I learned to keep my hand ready for the keys.
If i had been driving for an hour, parked up for 20 mins, it would take a bit longer for it to start up to.
Kitch
Unread post by Kitch »
Coolant temp sensor on the side of the head. Often mis-diagnosed as coil pack or stepper motor. Think its a green one and a brown one. Works out about £40 for the pair from the stealers, as most nen-gen suppliers can't seem to get them right!
Might not be for sure, but I reckon it probably is. Usually screws the idling and fuelling up a treat too.
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
