2000 2.0 HDi, just the other day I noticed that what I guess to be the tank fuel pump has got very noisy. Turn on the ignition and I get a really quite loud d-d-d-d-d-d-d sound for a few seconds. Then start the engine, and you can hear the sound again, like it's coming from the fuel tank.
Did a search and found this:
HDi fuel pump
When the guy suggests replacing the fuel filter and its housing, are we talking about the one in the engine bay, or is this another filter down by the fuel tank itself?
The engine bay fuel filter housing on mine is leaking, I think maybe from the drain tap, so it probably needs replacing anyway.
Look forward to your comments!
HDi Fuel Pump
ianrobbo
- x 1463
Oddly mine has gone quiet since I posted that, so is still on the to do list....
I think that if there is any pulsation from the LP pump in the tank, then it can set up a resonance with the filter causing the loud noise. If you listen near the tank and the filter whilst the ign is switched on then you should be able to isolate the noise. The filter is not expensive as a unit (£45 or so from GSF) - a lot cheaper than a new HP pump if it doesn't do it job properly (as has been known....)
ianrobbo
- x 1463
ianrobbo
nick
If you want to make obsolutely sure there's a filter element in there without taking the top of the housing off undo the drain screw at the bottom of the housing and gently poke something like the tip of a (clean!) watchmakers screwdriver in through the hole. If there's an element it will meet resistance almost immediately. If it will go right in then there's nothing inside!
Perhaps I'm paranoid, but it would be just my luck to get one that somebody at the factory forgot to put a filter in
pikecrazy
Yes it comes with oneianrobbo wrote:Richard,
May be a silly question, but does the GSF unit come with a filter already installed, or is it necessary to buy that in addition?
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
