Guys, i have a VSX with Hydractive,
Normally it rides super smooth. When you put it into "sport" suspension mode it handles alot better on bends and the road noise increases ever so slightly but unless you concentrate you cant really tell that much difference.
What i want to know is how much difference is it supposed to make? Is mine already kind of stuck in sports mode?
Hydractive and non hydractive, ride quality
- x 1449
- x 8170
Hi Vince,
Sounds like everything is in good working order there to me
The function of the comfort/sport switch is to adjust the thresholds when the suspension switches to hard mode. In sport mode the suspension will switch much more readily, hence the better handling. You will not notice any obvious, immediate change if you switch modes as it is a bit subtle.
The Hydractive system takes cues from the speed, rate of accelleration/decelleration and rate of change of steering input. Using all this information and the mode you select, the Hydractive ECu then makes the decisions on when to switch.
The Citroen Technical Guide gives a lot of information on how the Hydractive system works and has tables of the switching thresholds.
The comfort/sport switch even has a fair effect on an Activa, tightening up the already tight suspension quite significantly when sport is selected and it is being hustled along B roads
pete_wood_uk
Yup, sounds like it's working. As a quick check: Park the car on the drive with the engine running, and the suspension should be in "soft" mode. Applying pressure to bonnet or boot (I tend to use my arse
) should result in lots of travel. Very soft at the back, less so at the front. Stop the engine, and you'll probably hear a whistle which is the AC powering the solenoids holding the hydractive "soft" valves open. Lock the car up, and after a few seconds the whistle will stop and there'll be a click. Apply your nether regions again, and it should be a lot harder. That's hard mode.
As Jim says, unless you actually thump the switch in the middle of a series of bends, then you shouldn't notice any actual difference when you do so. I tend to drive mostly with the car in sport mode - it doesn't hurt the ride and there's less uncertainty as you approach a bend...
(Having said all that, mine's getting a bit hard all round now and sinking at the back when parked - I rang Mr Pleides the other day for some sphere pricing....)
Cheers
Pete
Cheers
Pete
Xantia HDi 110 Excl Estate 140k
C5 HDi 138 Estate
C5 HDi 138 Estate
- x 1387
Another test which I have used is to find a very quiet country road, and with ther suspension in soft mode mover the steering wheel to weave across two lanes as fast as comfortable at obout 35-40MPH, then while continueing to weave accross the road, hit the suspension switch, and you should feel the suspension tighten up.
vince
- x 13
Thanks guys.....some good advice there.....im not trying to find anything wrong with it honestly
It does definately make a difference when in sports to cornering...its on rails.
Im getting a full set of new tyres on saturday...some nice softer compound ones...all the same tread aswell on look like new alloys....i cant wait
Will no doubt help handling also somewhat.
I stil cant get over how amazing the ride is in this car....it puts the past Xantias i have had to shame....
DickieG
- Monaco's youngest playboy
- x 38
A simple test to see whether the electric side of Hydractive is working is to tune the radio to 171 LW, when its in hard mode the radio interference noise is reduced. The easiest way to switch the suspension into hard mode is to apply or release the accelerator quickly.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8170
Stempy
Another method is to remove the fuse to the HA ECU, than go for a drive, it will disable the electrovalves so soft mode can't be activated. You'll know what hard mode is all about then! (Remove dentures first)
Lexia ponce
Lexia ponce
pete_wood_uk
Oh yes indeedvince wrote:It does definately make a difference when in sports to cornering...its on rails.
Just out of interest, what tyres are you putting on it...?vince wrote:Im getting a full set of new tyres on saturday...some nice softer compound ones...all the same tread aswell on look like new alloys....i cant waitWill no doubt help handling also somewhat.
Cheers
Pete
C5 HDi 138 Estate
C5 HDi 138 Estate
vince
- x 13
