I have a renault megan with 1.9L DTI engine, will b100 work good with it or will it destroy it?
Elad.
renault megan and biodiesel
wonderd
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
Xantia 1.9L TD 99
tech-tonics
I suggest trolling the net about biodiesel in general B100 comes with lots of issues. It can release sediment that normal deisel wont (sediment thats already in the tank). It attacks seals / fuel lines that normal diesel wont and especially the seals in injector pumps. Many people do run on B100 (not sure about laguna's and theoretically it should work. But watch out for the bigger issues such as the seal and sediment issue. If the sediment gets into the injector pump it can damage the vital pistons and valves in the pump.
Most places recommend fitting a fuel filter with smaller holes and replacing fuel lines with biodeisel friendly.
Not an expert by any means and I was looking up info with regard to Oil Heating but the system is very similar. B100 has lower calorific value but is less dense. This means without changing the injectors mor fuel goes into the cylinder ofsetting the fact the fuel has lower calorific (power to weight ratio) value.
tt
tt
