Hi all,
My parents' Xantia 1.8i 8V 1996 model car is leaking LHM from the front-left brake caliper. Inspection shows that it's coming from a split in a rubber 'cap' that is cable-tied over a side projection on the caliper where the handbrake lever goes into the caliper.
I wondered if LHM is supposed to be in that capped area so the lever mechanism is constantly lubricated, but going by the rust on the parts in there, I'm wondering if it doesn't usually have LHM present and the cap is just a cover to prevent muck getting in.
Assuming that, inside there, the lever presses directly on the caliper piston, could it be the piston is leaking LHM past into the rubber boot, but shouldn't be?
If anyone knows more on it, I'd appreciate it, so I can get the bits and fix it while I'm here (Spain).
Thanks,
Xantia 1.8i front brake caliper question re: LHM leakage
JamesQB
- x 5
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
- x 8088
Hi James,
No, there should be no LHM in the boot concealing the handbrake linkage. Xac and I had that with his Xantia when we were doing the clutch. I grabbed the caliper to pull the driveshaft out of the gearbox and got an LHM shower all down my arm
I'm not sure if the caliper can be repaired or if a repair kit is available..
- x 8088
Just had a look on citroen.service.com.
It looks as if the O ring on the handbrake adjuster lead screw fails to cause this leak.
There is a repair kit available for £25 (part no. 95-651-051) that contains all the seals you need.
There is a bigger repair kit to fully rebuild the caliper for £50 (part no. 4427-98 )
andmcit
- x 30
- x 8088
AndersDK
- x 8088
Thanks AndersAndersDK wrote: - sorry I just edited Jim's post
JamesQB
- x 5
Thanks a lot for that information. Looks like I have a bigger job ahead of me that I expected, as well as needing to change 4 spheres while I'm here...
They went this morning to order the rubber boot from the not-so-local Citroen dealership, and I hadn't checked this thread back then, so I'd better get on the phone and see if that part number works for them and they can get the kit.
Big job fitting the new seals pack?
- x 8088
No, I don't think it is. Just don't try to remove the handbrake operating arm from the rear! You'll have loads of fun getting it all back together due to a very big spring. Work from the piston inwards.JamesQB wrote: Big job fitting the new seals pack?
Just check the part no. for the repair kits with your dealer to ensure you have the right one for your model. Calipers do vary a little between models and the one I quoted was for a 1.9TD (automatic reaction
JamesQB
- x 5
Well, luckily when my parents got to the Citroen dealership, they were told they'd need a kit as couldn't buy just the rubber boot on its own; one costing 40 euros, or a bigger one with a few extra bits for 60 euros. They chose the 40 euro one, which I'd say is the £25 kit you spoke of. Apparently it contains several bits and pieces, so fingers crossed it'll be the repair kit with the necessary seals.
You say to work from the piston inwards...does that mean removing the piston from the inside of the caliper and take bits out that way? Just wondering how I'd do that, does the piston unscrew out all the way? Only other question is will removing the piston allow me to pull out the adjuster lead screw as well, which requires the new seal?
Xaccers
- x 185
If someone can confirm that both the 1.9TD hatchback and estates use the same front caliper, I can pop up to Northampton on Saturday and buy a replacement for Cassy from the scrapyard there as it's going to be cheaper than £25.
Then I can take apart the old one and advise on how best to do it.
DIY sphere tool
DIY sphere tool
- x 8088
- x 8088
James,
The alternative part no. for a seal kit is 95 661 818. Both this and the part number I quoted earler is listed for various 1.8 models so when you order have your VIN and RP number handy to ensure you get the right ones.
I'd think the piston unscrews fully out of the caliper followed by the lead screw and spring to replace the seals. Seems logical but Xac will soon give us all the information needed
- x 1431
Jim - I'm chasing you round tonight disagreeing with you!!citrojim wrote:The front calipers are the same on the 1.9TD estate as they are on the Hatch Xac
I'm pretty sure the Estate has bigger front brakes than the hatch*, and hence the calipers are different. However, from the point of view of the handbrake mech they're probably the same. HDi 110, 2.0CT, 2.1TD and V6 use different brakes still.
*ISTR folk having trouble though with estate sized brakes on hatches and vice-versa. Just for fun!
- x 8088
RichardW wrote: Jim - I'm chasing you round tonight disagreeing with you!!
And there was I thinking only the rear calipers differed on estates...
