...starts of in the morning as -50 degrees rising to a balmy 4 degrees!!!!
As it's only external temperature reading I'm not that bothered but what's the gen on this? Is it worth replacing or too prohibitive financially?
C5 external/ambient temperature reading...
frenchcarnut
04 C5 2.0 Auto HDi VTR
- x 5582
frenchcarnut
philipte
Had the same thing on my C5 a few years back. I can confirm that it makes the climate control do some very strange things
The thermistor lives in the base of the N/S mirror. It's a bit of a PITA to get to, removing the mirror cover itself is best done on a warm day as the plastic is just that bit more flexible and the very fragile clips are less likely to break.
I cut and joined the new thermistor wires onto the old ones, and used some heat shrink tubing to seal the soldered joints. Its been absolutely fine ever since.
Hope this helps.
Philip
Hope this helps.
Philip
